Administrators MaLd0n Posted October 29, 2023 Administrators Posted October 29, 2023 How to update OpenCore and Kexts - Easy way with OCAT -Support Olarila Vanilla Hackintosh by making a donation HERE -About Premium Users you can check HERE -Problems with Paypal HERE -Installation Guide HERE -Hackintosh EFI folders HERE -Hackintosh USB Remap HERE -How to update OpenCore and Kexts HERE 1) Download OCAT HERE Credits: ic005k 2) Go to menu EDIT and Upgrade OpenCore and Kexts 3) Select All and Check for Kexts updates 4) Update Kexts Result 5) Get the lastest version of OpenCore 6) Start Sync 7) Save changes Check and load kexts again to avoid problems If you using other OpenCore version like OpenCore_NO_ACPI or need to use Opencore DEV follow instructions bellow. a) Select OpenCore DEV on menu EDIT b) Select DEV Source on Kexts, select OpenCore version, Get OpenCore, Start Sync and Save We're all here to have fun and learn from each other! That's all Folks! 6 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
jm26200 Posted February 9, 2024 Posted February 9, 2024 (edited) On 10/29/2023 at 1:56 PM, MaLd0n said: How to update OpenCore and Kexts - Easy way with OCAT 1) Download OCAT HERE Credits: ic005k 2) Go to menu EDIT and Upgrade OpenCore and Kexts 3) Select All and Check for Kexts updates 4) Update Kexts 5) Get the lastest version of OpenCore 6) Start Sync 7) Save changes Check and load kexts again to avoid problems If you using other OpenCore version like OpenCore_NO_ACPI or need to use Opencore DEV follow instructions bellow. a) Select OpenCore DEV on menu EDIT b) Select OpenCore version, Get OpenCore, Start Sync and Save Olá Sr Daniel, E para mim sem sucesso muito estranho (estou no OC 0.9.8 e quero 0.9.9 e tento os dois métodos, mas sem sucesso com sonoma 14.4 beta 2 e Sonoma 13.3.1,,,) Atualize o opencore versão 0.9.9, seja feito manualmente ou com OCAT, o menu gráfico desaparece Alguém teria alguma ideia? desde já, obrigado Edited February 9, 2024 by jm26200 Mac mini macOS Monterey 12.7.5 (21H1211) Carte mère : GA-Z590 UD AC, CPU : Intel BOX I5-11400 LGA : 1200, RAM 32 Go DDR4, Intel Rocket Lake-S GT1 - Graphiques AMD Radeon RX 6600 8 Go - OS: macOS Sonoma 14.5 [Open Core 1.0.0 ] (23F5059e) & Windows 11 Professionnel Insider Preview (canal Canary) 24H2 26200.5001
Administrators MaLd0n Posted February 9, 2024 Author Administrators Posted February 9, 2024 2 hours ago, jm26200 said: o menu gráfico desaparece X64.NO.ACPI.zip 2 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
jm26200 Posted February 9, 2024 Posted February 9, 2024 RESOLVED great thankxs sir Daniel Mac mini macOS Monterey 12.7.5 (21H1211) Carte mère : GA-Z590 UD AC, CPU : Intel BOX I5-11400 LGA : 1200, RAM 32 Go DDR4, Intel Rocket Lake-S GT1 - Graphiques AMD Radeon RX 6600 8 Go - OS: macOS Sonoma 14.5 [Open Core 1.0.0 ] (23F5059e) & Windows 11 Professionnel Insider Preview (canal Canary) 24H2 26200.5001
troyboy77 Posted March 21, 2024 Posted March 21, 2024 Hi is the update of opencore and update kexts needed if sonoma 14.4 is running fine and booting,with the proper modded efi folder? Thanks
Administrators MaLd0n Posted March 21, 2024 Author Administrators Posted March 21, 2024 For 14.4 stay with all things updated. 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
troyboy77 Posted March 21, 2024 Posted March 21, 2024 so i do need to update through ocvalidate? i see 12 updates needed
troyboy77 Posted March 21, 2024 Posted March 21, 2024 In the new efi after updates i see theoldconfiglist entry in there ,do i delete it from efi folder or just leave it as is?
Administrators MaLd0n Posted March 21, 2024 Author Administrators Posted March 21, 2024 U can delete this file. 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
troyboy77 Posted March 22, 2024 Posted March 22, 2024 Hi I am curious on something here .When I restart my mac ,at the beginning before the screen hits the menu for which option I want to boot to ,I hear a click.Is this normal and if not what could it be? Thks
Flexigem Posted December 4, 2024 Posted December 4, 2024 (edited) Hello Mald0n, I successfully updated OC Mod Dev 1.0.3 on my system. However I experience the same problem, that the graphical UI is lost after the update. Can you please explain what causes this and how to fix it. I would like to learn and understand this issue for future updates. Thanks https://imgur.com/a/MfnRIT5 [url=https://ibb.co/RjhJP3d][img]https://i.ibb.co/tLZ1cqF/IMG-0939.jpg[/img][/url] Edited December 4, 2024 by Flexigem
Flexigem Posted December 10, 2024 Posted December 10, 2024 Dear Mald0n, as you seem the only one to mess around with DEV Mod OC, you are my only help for the question above: What happens or what I am doing wrong when updating OC DEV MOD to the new release and only get a text based Bootloader screen instead the GFX with UI and Harddrive picker. I checked the OC config entry and its on external picker with Auto. Is the config being changed in some sort when OCAT validates? Thanks for your kindly help in advance 1
Administrators MaLd0n Posted December 10, 2024 Author Administrators Posted December 10, 2024 Set boot picker atributes to 145 1 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Flexigem Posted December 10, 2024 Posted December 10, 2024 WOW. Thats it. 145 instead of 255. Back to business with up to date 1.0.3 and functional GFX picker. You´re a hero! Thanks!!! 1
khemlani Posted April 11, 2025 Posted April 11, 2025 dear maldon I would like to know how to add the following to my kexts VoodooI2CSynaptics.kext.zip I couldn't figure out how to add this. please help thank you 1
Administrators MaLd0n Posted April 11, 2025 Author Administrators Posted April 11, 2025 55 minutes ago, khemlani said: dear maldon ??? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
khemlani Posted April 11, 2025 Posted April 11, 2025 (edited) 52 minutes ago, MaLd0n said: ??? this is an kext for the synaptic trackpad on the s145 but I don't know how to add it to the kext in the efi will appreciate your help thank you Edited April 11, 2025 by khemlani
Administrators MaLd0n Posted April 11, 2025 Author Administrators Posted April 11, 2025 Syna in many cases u need to edit kext with Syna name -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Oscar Films Posted July 16, 2025 Posted July 16, 2025 So I attached a photo of my desktop here. I was hoping you can tell me what I need and don't need from these files. It's become a bit of a mess. Just now I was finally able to download Seqouia and have gotten further than I did before reaching out here when it didn't seem possible to download the next OS upgrade. It seems like I'm a bit closer. But I would like to better understand OPEN CORE and how it applies to my system here. THANK YOU!!!!
Oscar Films Posted July 16, 2025 Posted July 16, 2025 ...And I just rebooted and my Hackintosh did NOT Take Seqouia installation despite the processing that seemed like it was gonna take. Any input?
Oscar Films Posted July 16, 2025 Posted July 16, 2025 So another attempt to install sequoia with no success here. Any idea why? Do I have to just install the old way with a flash drive?
Bunlong Bin Posted August 12, 2025 Posted August 12, 2025 (edited) hell Dear! MaldOn Nowday , you have upgraded EFI tiger lake for CPU intel 11th (Iris Xe Graphics) or not yet? Edited August 12, 2025 by Bunlong Bin
Oscar Films Posted August 24, 2025 Posted August 24, 2025 Hello! Thank you for the reply. I'm nit sure I understand though. If you are asking me if I have upgraded to that chip, then no I have not!
Cleo-Johnson Posted October 5, 2025 Posted October 5, 2025 While Hackintosh systems have empowered many users to experience macOS without the high cost of Apple hardware, I can't help but wonder about the longevity of this trend. As Apple tightens its hardware and software ecosystem, could we see a future where Hackintosh services become obsolete? What will happen to the community and innovation surrounding this once-thriving workaround?
