Try this efi folder EFI.zip
Hi again! I don't have AMD GPU anymore, I'm with Nvidia unsuported GPU even with patches, so I want to try again and use my Ryzen APU iGPU. I have desktop PC with Asrock A320m pro4 motherboard and Ryzen 3 2200G APU. I created USB installer, create EFI with patch for my CPU, but It can't boot into it. I select installer in OpenCore menu, starts booting for 2 seconds in verbose mode and just restarts the system. Can anyone help me what to change in my EFI? Also, I enabled iGPU from BIOS but do I need to remove my Nvidia GPU from the PC when trying to boot?
https://we.tl/t-VyrwpXQm2w
Edit: after I detach power connector of my Nvidia GPU, I make a little bit of progress - Nootedred is loaded, but it stuck here.
Edited by Georgi Pehlivanov
