Need help with dual 2K monitors DP no work Ventura HD530 6600k Z160
Hello everyone,
I'm reaching out for assistance with a Hackintosh setup issue I'm experiencing. I recently attempted to install Mac OS Ventura on my machine, which is equipped with an ASUS Z160 Pro Gaming motherboard, an Intel 6600k CPU, and an Intel 530 GPU.
My issue revolves around my dual 2K monitor setup. Both screens are connected – one via HDMI and the other via DisplayPort. However, only the monitor connected through HDMI seems to work correctly, while the one connected via DisplayPort isn't producing any signal.
I am willing to provide my config.plist file or any other relevant information that might help diagnose and resolve my issue.
Has anyone encountered a similar problem or can guide me through the steps to fix it?
Thank you in advance for your help and expertise.
Best regards, latour500
I hope that helps! Let me know if there are any other changes or modifications you'd like.
config.plist.zip
Hi,
Thank you very much for this link, in fact there is a lot of information and I am a beginner in hackinstosh so I admit that I am completely lost, hence my request for help.
(i use opencore)
