Problems with Catalina installer the system always reset
Hi everyone i'm Salvo,
My Notebook is an HP 15-bs0xx - Intel core i5 7200U - Intel Graphics HD620 + AMD R5 M330 Chipset: Kabylake SouthBridge: Coffeelake-U/Y PHC.
I have followed the tutorial, so i have downloaded the image and the EFI folder then, with BalenaEtcher, created a bootable USB.
In the USB i have copy and Paste the EFI Folder previusly downloaded. Cheked if in the kext folder were present some kext like lilu, whatever green, usb2 ect.
So i have reset the pc, turned on the virtualization and legacy, turned off the secure boot. Set the USB at first place and saved settings.
The Pc after that load clover boot and in in boot arg: was also present the -wagnoegpu igfxonl=1 "i think this disable the 2 GPU"
When i press on the installer Icon, the system display me some strings and then the string with "System reboot after panic" and the pc reset.
I don't know what to do, i've tried many times and with various tutorial online but nothing. In the Clover boot i've press also F4 to send you the file but i don't know where it is.
So can you help me please? Thanks a lot.
-NoteBook KabyLake Download HERE
-Procedure-
-Bios/UEFI in full default settings(Just change CSM to Disable if you have a AMD GPU and Sata to Ahci)
I've used your link for the EFI folder for kabylake, and also followed your advice but it doesn't work. And it start with opencore not with clover. i have to do something else? thanks
-igfxvesa
