Hello! I am trying to install MacOS on my Huawei Matebook with an i9-13900H processor (RaptorLake) and i can`t figure it out. I can`t find any raptor lake efi files for laptop except the 700 series efi folder and when i try to use that it shows some errors about processor.
U can use this efi folder but need check correct fakecpuid
btw this IGPU don't have support under macOS
