My Hackintosh System:
Alienware Aurora R16 running Sonoma 14.1
13th Gen Intel Core i9-13900F
64GB DDR5
NVIDIA GeForce RTX 4070 Ti - 12GB
**Alternate Video Available: Radeon RX 580 8 GB
Killer AX 1675 Net/WiFi/BT
System Drags, has issues with any moving images/video.  Finder folders, opening/closing, causes system to stall.  Everything seems operational, yet adding name in messaging settings crashes messenger.  Weird quirks here and there.  Would greatly appreciate review, corrections, suggestions.  Listed alternate Video Card above as it is working amazing in an older Alienware running Catalina.
Just to note that I also donated yesterday.  Why? Because your amazing EFI install was successful after dozens of other methods prior!!!  So thankful!
My Sendme File is almost 20mb and will not upload.
Can download from Google, or please provide me other method:  https://drive.google.com/file/d/1G8a_gi9p8ytth4WEqZmwgK_JHO2nZjnG/view?usp=share_link
Thanks again!!!
donation.png.zip
Use this efi folder with these instrcutions bellow https://www.transfernow.net/dl/20231008bkk6YytK
After reboot save one ioreg https://olarila.com/files/Utils/IORegistryExplorer.app.zip
U need to use rx580. U can stay with both cards. I can disable NVIDIA under macos
