Hi, how are you? Can you help me? I have a z490 asus prime-p with i5 gen10. I already modified the config.plist and added framebuffer. I don't know if I did it correctly with the bootargs. Igfxvesa works. I manage to install sonoma beta 7 but I can't do anything.
my problem is black screen
config.zip
Full hardware spec?
fenvi 1200m wifi and bluetooth, z490 asus prime p, i5 10400 igpu no gpu ssd 480gb ram 16gb
I have an RTX gpu but I use -wegnoegpu or I disconnect it to install sonoma. The mother is new. I never installed another macos. I changed my mother. Before, I had an h410 but it had a problem.
I have windows 11 installed on another disk
Try
https://www.transfernow.net/dl/20230914PNVN3T5C
monitor connect on IGPU
-Procedure-
Follow these options
