Hello,
I am struggling to get the sleep to work. Every time I select sleep, wait until it goes to sleep, when I press power button or open my lid, it just turns on and shutdown.
Spec:
Intel HD 4400 Mobile
Intel i5 4200U Haswell
8GB Ram
DSDT/SSDT, Config.plist, and ioreg are attached.
I cannot upload due to zip file being too large (1.6mb). So I uploaded to dropbox.
https://www.dropbox.com/s/bi6reg91slmck37/SSDT%20DSDT%20Config%20IOReg.zip?dl=0
Any help would be great. Thanks.
Edit:
When I did fresh install, 10.9.0, sleep works fine, with the same DSDT, SSDT, and Config. But now I am on 10.9.5, sleep no longer works.
the *.aml files are not patched .. u are using it ?
if they are patched .. u don't need to use they
just apply the necessary fix for the dsdt in clover..
http://clover-wiki.zetam.org/Configuration#Config.plist-structure
http://clover-wiki.zetam.org/Configuration/ACPI#DSDT-/-Fixes
really don't see any patch in it .. what patch u apply ?
the ssdt only errors ..
also the dsdt
also the dsdt
Following things I have patched in DSDT are:
Audio Layout 12 (changed to 28)
GFXO to IGPU
Asus N55SL
Mutex with non-zero symbol
pnot/ppnt
asus fn keys patch
backlight keyboard patch
if is patched .. and work before ..
no idea.. wait for future updates..
see what is sleep and wake reason on console..
