Trijal Posted July 31, 2023 Share Posted July 31, 2023 (edited) Hey guys! Recently, my laptop broke and the plastic is degrading. I'll no longer be maintaining this EFI anymore. If anybody wants ownership to maintain the EFI, just contact me! Here it is for macOS Big Sur to Sonoma! PLEASE READ EVERYTHING BELOW BEFORE USE! CLICK ME TO DOWNLOAD OPENCORE To download the EFI on GitHub, all you have to do is click "Source code (zip)" under the assets section and you're ready to go! Everything works except for HDMI, for Wi-Fi in macOS Sequoia 15 you need to use HeliPort. On macOS Big Sur to Sonoma, it is built in to macOS. Also, it is reccomended that you use the YogaSMC app for the best experience out of this Lenovo laptop! Always check back for updates every 20 or so days. You'll be able to see the update(s) in the reason for editing at the bottom. Furthermore, if you don't know the difference between OpenCore and OpenCore MOD; it is that the MOD version can boot into other operatings systems except for macOS without injecting the Hackintosh stuff to them. Please donate to me on Ko-Fi if you really appreciate my work 🙏😅! Any amount would be so beneficial to me! CLICK HERE TO DONATE! Please pin and star this topic🙏😅 @MaLd0n. It is very useful! Edited 8 hours ago by Trijal Read the top! Quote Consider donating to me through Ko-Fi if you appreciate my work here!😁 Link to comment Share on other sites More sharing options...
Trijal Posted August 1, 2023 Author Share Posted August 1, 2023 @MaLd0n Please pin this topic. Sent from my EML-L09 using Tapatalk Quote Consider donating to me through Ko-Fi if you appreciate my work here!😁 Link to comment Share on other sites More sharing options...
pidipy Posted August 17, 2023 Share Posted August 17, 2023 Hello, on this EFI don't work bluetooth Quote Link to comment Share on other sites More sharing options...
Manuel Campos Posted August 23, 2023 Share Posted August 23, 2023 for wifi AirportItlwm version 2.3 and bluetooth IntelBluetoothFirmware version 2.4 Quote Link to comment Share on other sites More sharing options...
Trijal Posted August 24, 2023 Author Share Posted August 24, 2023 On 8/23/2023 at 11:57 AM, Manuel Campos said: for wifi AirportItlwm version 2.3 and bluetooth IntelBluetoothFirmware version 2.4 Sorry I will update the EFI in 30 minutes. Thank You for your patience! Quote Consider donating to me through Ko-Fi if you appreciate my work here!😁 Link to comment Share on other sites More sharing options...
Xenofon Konitsas Posted September 10, 2023 Share Posted September 10, 2023 @Trijal Hey, I've got the same laptop with the i5-1035G1. While everything works, I have really bad screen flickering when graphics acceleration is enabled. Any ideas on how to fix that? Quote Link to comment Share on other sites More sharing options...
Trijal Posted September 16, 2023 Author Share Posted September 16, 2023 On 9/10/2023 at 5:02 AM, Xenofon Konitsas said: @Trijal Hey, I've got the same laptop with the i5-1035G1. While everything works, I have really bad screen flickering when graphics acceleration is enabled. Any ideas on how to fix that? Can you please send me screenshot of when it happens? Thank You! Quote Consider donating to me through Ko-Fi if you appreciate my work here!😁 Link to comment Share on other sites More sharing options...
Nicolás Surace Posted December 7, 2023 Share Posted December 7, 2023 Hi. You can see here the problem that @Trijal a I have. I think it’s related with the Core Display Clock. Quote Link to comment Share on other sites More sharing options...
max_max_1946 Posted February 19 Share Posted February 19 Hi Trijal I had to reinitialize our magical laptop and I don't remember the correct bios settings could you give me a refresh Thank you Quote Link to comment Share on other sites More sharing options...
Trijal Posted March 3 Author Share Posted March 3 On 2/19/2024 at 1:18 PM, max_max_1946 said: Hi Trijal I had to reinitialize our magical laptop and I don't remember the correct bios settings could you give me a refresh Thank you Set boot mode to UEFI and set disk to AHCI. Also, don't forget to disable Secure Boot. You have to make all these changes to the BIOS by pressig F2 after pressing the power button to turn on. Quote Consider donating to me through Ko-Fi if you appreciate my work here!😁 Link to comment Share on other sites More sharing options...
freiserk Posted April 14 Share Posted April 14 I use the May 2023 version on a Lenovo IdeaPad 3 14IIL05 and it's going great. The most current versions do not work for me when changing EFI. Many thanks. Quote Link to comment Share on other sites More sharing options...
Trijal Posted May 16 Author Share Posted May 16 On 4/14/2024 at 12:23 PM, freiserk said: I use the May 2023 version on a Lenovo IdeaPad 3 14IIL05 and it's going great. The most current versions do not work for me when changing EFI. Many thanks. Maybe you should try the new version again and tell me what happens? That would be very helpful to me. Quote Consider donating to me through Ko-Fi if you appreciate my work here!😁 Link to comment Share on other sites More sharing options...
Trijal Posted May 16 Author Share Posted May 16 On 4/14/2024 at 12:23 PM, freiserk said: I use the May 2023 version on a Lenovo IdeaPad 3 14IIL05 and it's going great. The most current versions do not work for me when changing EFI. Many thanks. If it still does not work, archive and send your current EFI, as you won't be able to run the latest macOS and get performance updates otherwise! Quote Consider donating to me through Ko-Fi if you appreciate my work here!😁 Link to comment Share on other sites More sharing options...
Trijal Posted May 17 Author Share Posted May 17 On 12/6/2023 at 10:58 PM, Nicolás Surace said: Hi. You can see here the problem that @Trijal a I have. I think it’s related with the Core Display Clock. I think I might've fixed with this current update. If I did not, please inform me. If you find a solution, you are more than welcome to tell me how to patch it! 😅 Quote Consider donating to me through Ko-Fi if you appreciate my work here!😁 Link to comment Share on other sites More sharing options...
jcd1sc1ple Posted Saturday at 06:31 PM Share Posted Saturday at 06:31 PM (edited) I am having trouble booting the EFI from the SSD. When it is loading the OS it freezes with 0%. I can boot fine from the USB. Thank you for this EFI BTW. Edited Saturday at 06:32 PM by jcd1sc1ple Quote Link to comment Share on other sites More sharing options...
Trijal Posted Saturday at 11:40 PM Author Share Posted Saturday at 11:40 PM (edited) 5 hours ago, jcd1sc1ple said: I am having trouble booting the EFI from the SSD. When it is loading the OS it freezes with 0%. I can boot fine from the USB. Thank you for this EFI BTW. Open Config.plist and add the boot-arg "-v" to the boot-args section in NVRAM. Do this with OCAT OpenCore tool or whatever you use. After that, try booting from the SSD again. By the way, which macOS version are you using? Oh, and make sure to send a video of the verbose/logs when booting from SSD. Edited Saturday at 11:53 PM by Trijal Quote Consider donating to me through Ko-Fi if you appreciate my work here!😁 Link to comment Share on other sites More sharing options...
Join the conversation
