On 2/6/2025 at 3:06 PM, openminded said:
hi, I followed the instructions and tried both attached kexts and latest.
Since Sequioa I get at bluetooth BCM_4350C2 and Address NULL.
That's on a intel 8260 card.
It worked shortly on Big Sur but I can't get it to work.
Anyone any idea? Using NVRAM settings and beta param on boot args too.
After the upgrade the bluetooth card shows like that, on Big Sur there was nothing so it looks like the upgrad did this ?
Also there with no drivers loaded.
Any help is appreciated!
same for an intel 3165 plus, osx 15.3
Intel?
20 minutes ago, MaLd0n said:
Intel?
Huh? Yes as I wrote :). I actually found the issue, it was incorrect usb port mapping. Usbtoolbox didn't seem to work properly. Remapped and used Usbportmap only and it works now. Thank you.
Only with OCLP...just avoid it.
Hi everyone, anyone get itlwm get working, i use many tips but nothing work the kext does not load on Tahoe, kexts for BT ok but not for wifi.
Any ideas???
Asus Vivobook X512DA Ventura 13.5 (ventura works like a charm)
Lenovo ideapad Z710 on sequoia 15.7
Desktop: Asus Z97-C|CPU intel i7 4770K|Nvidia GT 720 2GB|Sequoia 15.6.1| OC 1.0.6
Iphone 14 128GB ios 26
Just work fine on Tahoe
