Woytek Pośpiech Posted November 1, 2023 Posted November 1, 2023 Thanks. All working fine on Asus Rog GL552VW .
Expatriate Posted November 8, 2023 Posted November 8, 2023 (edited) Thanks. Wifi and Bluetooth Working on Asus Z590 Maximus Hero ( Intel Wi-Fi 6 ax210/ax211/ax411) Edited November 8, 2023 by Expatriate
Administrators MaLd0n Posted November 8, 2023 Author Administrators Posted November 8, 2023 Enjoy! -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
The_Winner_ 02 Posted April 3, 2024 Posted April 3, 2024 (edited) On 7/30/2023 at 3:41 PM, MaLd0n said: Just Inject these kexts with Bootloader on macOS SonomaWIFI.BT Intel Sonoma.zip Add these patches on NVRAM 7C436110-AB2A-4BBB-A880-FE41995C9F82 Credits: zxystd on https://github.com/OpenIntelWireless/itlwm Hi, followed the instructions on monterey and the switch is enabled but the bluetooth and the wifi don’t turned on . (See the photo) IMG_0539.zip Edited April 3, 2024 by The_Winner_ 02
Administrators MaLd0n Posted May 16, 2024 Author Administrators Posted May 16, 2024 Yes -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Administrators MaLd0n Posted June 26, 2024 Author Administrators Posted June 26, 2024 --Update kexts on first post.-- -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Alexsander Fernandes Posted June 27, 2024 Posted June 27, 2024 I finally come to fix the Bluetooth, works fine in my DELL Latitude 5590 i7-8th gen, Sonoma 14.5. 1
sonudbm Posted December 14, 2024 Posted December 14, 2024 Hey @MaLd0n, PCIe Adapter is Not Working I buy this ( Archer TX20E - AX1800 Wi-Fi 6 Bluetooth 5.2 PCIe Adapter ) https://www.tp-link.com/in/home-networking/pci-adapter/archer-tx20e/ I tried too many thinks, but wifi and bluetooth is not working I Tried all Intel Kext, Broadcom kexts Device info : Asus B-360 F gaming i3 -8100 AMD Radeon RX 570 Sonoma 14.5 Using your Coffelake EFI Folder - It is not detecting PCIe, so i add "SSDT-OLARILA.aml" Screenshot 2024-12-14 at 6.34.51 PM.zip
Administrators MaLd0n Posted December 14, 2024 Author Administrators Posted December 14, 2024 THis wifi just need kext. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
sonudbm Posted December 14, 2024 Posted December 14, 2024 (edited) which one .. i tried all these https://openintelwireless.github.io/ 5 minutes ago, MaLd0n said: THis wifi just need kext. which one .. i tried all these itlwm.kext AirportItlwm.kext IntelBTPatcher.kext IntelBluetoothFirmware.kext AirportItlwm_v2.3.0_stable_Sonoma14.4.kext.zip BlueToolFixup.kext and more. Also trying to rebuild a new Config.plist Edited December 14, 2024 by sonudbm
sonudbm Posted December 15, 2024 Posted December 15, 2024 Hey @MaLd0n, i return the ( Archer TX20E - AX1800 Wi-Fi 6 Bluetooth 5.2 PCIe Adapter ). Can you please give advice, which one Should i Buy for WIFI and Bluetooth - PCI-e, M.2 or Usb - Suggest a Model or Brand
Administrators MaLd0n Posted December 15, 2024 Author Administrators Posted December 15, 2024 Intel or broadcom -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
openminded Posted February 6 Posted February 6 hi, I followed the instructions and tried both attached kexts and latest. Since Sequioa I get at bluetooth : BCM_4350C2 and Address NULL. That's on a intel 8260 card. It worked shortly on Big Sur but I can't get it to work. Anyone any idea? Using NVRAM settings and beta param on boot args too. After the upgrade the bluetooth card shows like that, on Big Sur there was nothing so it looks like the upgrad did this ? Also there with no drivers loaded. Any help is appreciated!
openminded Posted February 7 Posted February 7 On 2/6/2025 at 3:06 PM, openminded said: hi, I followed the instructions and tried both attached kexts and latest. Since Sequioa I get at bluetooth : BCM_4350C2 and Address NULL. That's on a intel 8260 card. It worked shortly on Big Sur but I can't get it to work. Anyone any idea? Using NVRAM settings and beta param on boot args too. After the upgrade the bluetooth card shows like that, on Big Sur there was nothing so it looks like the upgrad did this ? Also there with no drivers loaded. Any help is appreciated! same for an intel 3165 plus, osx 15.3
Administrators MaLd0n Posted February 8 Author Administrators Posted February 8 14 hours ago, openminded said: same for an intel 3165 plus, osx 15.3 Intel? -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
openminded Posted February 8 Posted February 8 20 minutes ago, MaLd0n said: Intel? Huh? Yes as I wrote :). I actually found the issue, it was incorrect usb port mapping. Usbtoolbox didn't seem to work properly. Remapped and used Usbportmap only and it works now. Thank you.
striker_55 Posted March 8 Posted March 8 How can I get Intel Wi-Fi and Bluetooth working natively on Sequoia 15.3.1 or later without using HeliPort? 1
Administrators MaLd0n Posted March 8 Author Administrators Posted March 8 Only with OCLP...just avoid it. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
striker_55 Posted March 9 Posted March 9 I can install it with OCLP, but I can't use it natively after installation; I can use it with HeliPort.
Cleo-Johnson Posted October 5 Posted October 5 What hidden features have you discovered in your Hackintosh setup that completely transformed your experience? Share your tips and tricks!
moishiteru Posted October 13 Posted October 13 Hi everyone, anyone get itlwm get working, i use many tips but nothing work the kext does not load on Tahoe, kexts for BT ok but not for wifi. Any ideas??? Asus Vivobook X512DA Ventura 13.5 (ventura works like a charm) Lenovo ideapad Z710 on sequoia 15.7 Desktop: Asus Z97-C|CPU intel i7 4770K|Nvidia GT 720 2GB|Sequoia 15.6.1| OC 1.0.6 Iphone 14 128GB ios 26
Administrators MaLd0n Posted October 13 Author Administrators Posted October 13 Just work fine on Tahoe -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
