I've been trying to get the graphic accelerated, no luck on Ventura and no luck on Sonoma as well , only showing 5MB using 12345678 but as soon as I try to use what's recommended for HD 620 ( not UHD 620 ) get black-screen after verbose/apple loading logo .  Only need built-in panel since it's a 17" laptop .
Laptop specs
I5-7200U
HD 620 graphics
8GB ram .
config.plist.zip
Edited by KazuDante
-NoteBook KabyLake Download HERE
Tried before , in that particular case it was the same , only invalid id(s) gave a display output or setting -igfxvesa .
Also it's the same issue on Ventura 13.4 , can't change anything in bios related to this plus I don't know of any other method that would at least tell me how much is dedicated to graphics , if it 32 64 128 ect...   Any ideas on what I can do or is it a loss-cause ?
