Seeking Help: Audio Troubleshooting for Hackintosh with ALC897 Codec on Ventura 13.4.1
I'm having trouble finding a solution for audio on my Hackintosh.
I'm using version 13.4.1 of Ventura. My codec is ALC897.
I've tried using AppleALC, testing all possible IDs. It worked a few times with different IDs, but never consistently across reboots or shutdowns.
I've performed OpenCore debugging multiple times, and in all the logs, it successfully injects the ID. I'm quite lost; I've visited many forums and tried various things, but I haven't made any progress, and I don't recognize any patterns in its functionality. It seems very random.
I've also tried the HPET fix with SSDTTime, but it didn't help.
I've reinstalled the system twice, and I still encountered the same problem.
CPU: i9-11900H
Chipset: HM570
GPU: RX 5700 XT
I've attached the plist. I appreciate any suggestions you might have.
config.plist.zip
I managed to get the audio working.
In one of the few times I succeeded, I'm attaching an image of the IORegistry.
I would like to know if, in case I reboot the system and the audio stops working, inserting the properties present in the registry directly into my DeviceProperties should make it work, correct?
But, I don't know if layout-id <07 00 00 00> is 7 in decimal. In any case I'll put data format.
Screenshot 2023-07-07 at 09.37.05.zip
