Hi Mald0n
I would like to request a dsdt for my system. It is 70% working.
Issues: slow usb ports, lower cpu speed (have 60% of Geekbench score than I have in windows) slow system after wake
I have a flashed thunderbolt card installed and a firewire card
usb bluetooth is working now, should the integrated one also work?
here is the file https://www.dropbox.com/s/rwjzyrivmovbtj2/Send me Mac-Pro.zip?dl=0
thank you
have a nice day
Viktor
Thank you Mald0n, really nice job. usb s are fine, just 2 things.
At thunderbolt card hard drive doesn't come up, cannot even see it at system info/thunderbolt tab.
(should I plug the extra thunderbolt connector to the motherboard? as I know well the flashed one I don't have to)
the cpu with the same bios settings at geekbench6 at win got scores 2855/20750 and osx just 2430/16900. Is this fine? At my previous ryzen I had 30%more multithread points (and better performance at audio usage too)
thank you
Edited by fojerhar
just set xmp and enable vt-d
Hi Mald0n
Thank you for the dsdt. Many things are working perfectly.
With the attached thunderbolt aml my system was not starting, restarted immediately continuously
With this one it is perfect with hot swap also
I have installed additional 32Gb of memory with totally same type, but with 64gigs now I cannot use xmp, system randomly restarts after 10-20 seconds
thank you
SSDT-TBOLT32-KGP i9b.zip
