Sleep/Wake USB problems. Acer Aspire 5
Hy all.
I have a Acer Aspire 5 A515-52G-79NN
CPU- i7-8565U
16GB DDR4 2666Mhz Ram
Intel UHD 620 (working) plus Nvidia Geforce MX130 (unsupported).
Wifi+Bluetooth BCM943602CS with NGFF M.2 Key A/E-Key Adapter.
OLVINS Bluetooth 4.0 Bt Wireless WiFi Airport Card BCM943602CS BCM943602CSAX substituição para MacBook Pro 13" 15" Retina (2015) A1398 A1502 653-0194 802.11ac : Amazon.es: Computadores
JSER Xiwai BCM94360CS2 BCM943224PCIEBT2 Cartão sem fios para NGFF M.2 Key A/E-Key Adapter : Amazon.es: Computadores
Dual Boot, Windows 11 Pro SSD Crucial 1000GB, Macos Ventura Nvme Samsung 970EVO.
Bios settings all enabled/disabled as required for MacOs.
Wifi+Bluetooth working flawlessly in MacOs and Windows, if someone wants I can provide drivers for Windows, dated 2020, compiled by me. I had issues of windows hanging and freezing with a lot of different drivers found here and other foruns, but mine I can stand for that they work 100%.
I have my bluetooth devices working cross OS, I edited regedit on windows, following some tutorials here and ******, all working.
My issue is usb and sleep/wake.
I have my SSDT´s compiled by me on Windows, patched.
All USB´s mapped with all the tools available, but no luck, I deleted all my usb kext´s from OC/Kext folder and no luck.
I made a log and from what I can see, the issue is related to:
localhost kernel[0]: (AppleACPIPlatform) AppleACPIPlatformPower Wake reason: XDCI CNVW
I tried lots of possible solutions that I search for but no luck.
Symptoms: Goes to sleep: wakes instantly and usb stick removed before disconnected message.
My perfect Hackintosh lacks this fix for full 100%.
I hope someone can help me.
P.S.- I deleted all my PlatForm serials...
Thank You all.
Best Regards,
My EFI
https://mega.nz/file/OMxFQDgI#s1alLSaSw64Mj6dKQftsWSZiMaGlYnBkMMwZi6VashU
Hugo.
Edited by hugocarmo
Good night.
My problem is fixed. Another forum helped me.
If someone need my EFI settings or windows drivers 100% working and compiled by me for BCM943602CS, I can provide links.
Thank You.
Hugo.
On 7/6/2023 at 6:38 PM, hugocarmo said:
Good night.
Thank You.
Hugo.
Hi friend. Can you provide link for wifi drivers please?
