Hello MaLd0n,
Thank you first of all for welcoming me to this forum, I am a beginner and I am learning in quick succession, I have a Hp Prodesk 600G2 mini i5 6500T 16go ram which has just started on Monterey, everything is ok (smooth video / sound / ) but the only problem is the USB ports which do not recognize external hard drives (USB2/USB3/C SSD etc),
I admit that I have read the tutorial that is here on the subject (Hackintosh USB Port Mapping Guide) but I may be doing it wrong.
An advice from you before sending you the EFI file (I prefer to learn and understand)
THANKS
Update to last opencore and enable xhci patch
