hugocarmo Posted June 18, 2023 Posted June 18, 2023 Hi everyone. I´ve been trying to install macOS as Hackintosh (Opencore). I have Windows 11 and macOS Big Sur 11.7.7 installed on different drives, my setup is humble, I´m on a Toshiba Laptop Satellite L50-A-1CU, specs: i7-4700MQ Chipset HM86-8C49 GPU: Intel HD4600 and (Nvidia Geforce 740M Disabled) Wifi (replaced by me) Intel N7260 Ethernet: Atheros AR8171/8175 Audio (main issue), IDT92HD99BXX. As I read and followed all guides and tutorials, the layout is "3", I tried, with bootargs, injected but can´t make it work. All my DSDT are made through my laptop and patched (I think) (Windows SSDTTime) followed all guides I could find out, but no luck. I´ll attach all my PR files, hope none is missing... Also in the zip file goes the Windows AIDA64 report attached. And, after every reboot my bios changes secure boot from disabled to enabled, I have dual boot, so have brightness keys working, but only sometimes, I press them, I see the level going up or down, but sometimes it changes nothing, and sometimes I see brigthtness changing... Thank You all! What I have working... Wi-FI, ethernet, usb´s, bluetooth, battery stats, brightness keys (sometimes). Best Regards, P.S-I removed AirportItlwm.kext from OC folder because it´s to big and couldn´t attach the file in my thread. Hugo. https://we.tl/t-fiPppPQo2a
Administrators MaLd0n Posted June 18, 2023 Administrators Posted June 18, 2023 Audio check here https://www.olarila.com/topic/6074-guide-easy-audio-solution-with-applealc/ -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
Alex_F3r Posted Tuesday at 11:35 AM Posted Tuesday at 11:35 AM On 6/18/2023 at 2:23 AM, hugocarmo said: Hi everyone. I´ve been trying to install macOS as Hackintosh (Opencore). I have Windows 11 and macOS Big Sur 11.7.7 installed on different drives, my setup is humble, I´m on a Toshiba Laptop Satellite L50-A-1CU, specs: i7-4700MQ Chipset HM86-8C49 GPU: Intel HD4600 and (Nvidia Geforce 740M Disabled) Wifi (replaced by me) Intel N7260 Ethernet: Atheros AR8171/8175 Audio (main issue), IDT92HD99BXX. As I read and followed all guides and tutorials, the layout is "3", I tried, with bootargs, injected but can´t make it work. All my DSDT are made through my laptop and patched (I think) (Windows SSDTTime) followed all guides I could find out, but no luck. I´ll attach all my PR files, hope none is missing... Also in the zip file goes the Windows AIDA64 report attached. And, after every reboot my bios changes secure boot from disabled to enabled, I have dual boot, so have brightness keys working, but only sometimes, I press them, I see the level going up or down, but sometimes it changes nothing, and sometimes I see brigthtness changing... Thank You all! What I have working... Wi-FI, ethernet, usb´s, bluetooth, battery stats, brightness keys (sometimes). Best Regards, P.S-I removed AirportItlwm.kext from OC folder because it´s to big and couldn´t attach the file in my thread. Hugo. https://we.tl/t-fiPppPQo2a have u found a fix? I also have a Toshiba Satellite L50-A-1FQ with the exact same cpu, gpu and brightness and sound issues, I installed azure wifi + br card for full continuity features and works very good, just this sound and brightness are a bit annoying, I've tried Big Sur with macbookpro11,3 and Monterey with macbookpro11,4 smbios
