For macOS Big Sur
CPU: Intel Core i3-4000M 2.40GHz
GPU: Intel HD Graphics 4600
BIOS Version: Hewlett-Packard L74 Ver. 01.50
Edited by Winnie3101
-Procedure-
-USB Remap https://www.olarila.com/topic/14220-hackintosh-usb-port-mapping-guide-2023/
