Hi all,
After almost one full day, I managed to get Mavericks 10.9.5 working just as I want. The only problem now is that I only have Internet connected via Ethernet and I'd like to connect via WiFi. My Asus K55VD network card is NOT compatible with any mac os system, so I'd like to change it so that I can get fully functional WiFi connection.
So, do you know which is the best network card adapter for a laptop? I'd like to have at least 50-100Mbps.
I found Dell DW1397 Broadcom 4312 Wireless Card but first of all I want to check other cards and buy the best one for my needs.
Thank you very much in advance!
Best regards!
Asus k55VD - Core™ i7 3670QM - Intel® Chief River Chipset HM76 - 6GB DDR3 RAM - Altec Lansing® - NVIDIA® GeForce® 610M with 2GB DDR3 VRAM and Intel HD Graphics 4000 - DUALBoot with Mavericks 10.9.5 and Windows 8.1 Pro
Hi!
Thank you very much! I've just bought this one: BCM943225HMB (2.4 GHz, bgn, 2 stream, 108 Mbs + BT (3.0)) for only $9 at eBay. As soon as it arrives at home, I'll install it and get it working by following this sources:
1. https://github.com/toleda/wireless_half-mini
2. http://www.tonycrapx86.com/network/120181-bt-wifi-working-ga-h87n-wifi-customac-mini-using-bcm943225hmb.html
3. http://www.insanelymac.com/forum/topic/292542-airport-pcie-half-mini/
Thank you again! I'll be back!
Regards!
