22944 Posted May 21, 2023 Posted May 21, 2023 fx577ze-hn072ws asus tuf gaming f15 12700h alder lake .iris xe graphic nvidia rtx 3050ti ddr5 16gb recently i installed ventura[beta] iso in vmware[17] then inside it logic pro x [10.7.7] everything else work fine but it crash when i accedently click on something thatt require gpu saying a warning that u r running macos in non supported envirement https://imgur.com/YUMY9Ow is there any script or patch / hack to use graphics that my laptop had or anything like egpu with minimum price range that can work with it https://imgur.com/a/WIWPInh any solution will be welcomed instad of buying a mac ============================================= i wanna run logic pro x only ============and thats it anything my laptop is eligible to do for running it plz tell me thnks
Administrators MaLd0n Posted May 22, 2023 Administrators Posted May 22, 2023 Apps need a video acceleration. I think this problem is that. -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Hackintosh Support since 2006 HERE
22944 Posted May 22, 2023 Author Posted May 22, 2023 9 hours ago, MaLd0n said: Apps need a video acceleration. I think this problem is that. https://imgur.com/a/avgVfRh what should i do now i alredy checked those boxes
