I am facing this problem
(Stuck at [IGPU] Scheduler Throttle Cap =100ms.)
after the installation of mac os catalina.
I have installed macOS Catalina using opencore.
After the installation I tried to boot the macOS from my hard drive.
But it is stucking at
my EFI folder:
https://drive.google.com/drive/folders/1cekFXenNwzN2tm_R1-b1tPf9Uiw-bXXJ
My PC specifications :
Acer Aspire v3-574
Intel(R) Core(TM) i3-5005U CPU @ 2.00GHz   2.00 GHz
12 gb ram
Intel® HD Graphics 5500
Olarila Catalina raw file
Tried broadwell EFI from Olarila.com
image file url : https://link-center.net/462274/olarila-catalina
I will be thankfull to Olarial vanila hackintosh Comunity if you help me to overcome this problem.
