Hello, when changed efi to clover in efi partition it changed only in partition but it booted default opencore thingy when i changed to clover
My laptop is
CPU Intel Core i5-2520m
only integrated Intel HD Graphics 3000
i forgot to say i deleted opencore efi
Also opencore just hangs on blinking _ thing
I dont understand
i followed guide carefully second time after you said and still opencore
i have a powerbook g4 and it can mount efi partition through terminal
i will try that and i will tell you if it worked
and sorry for late reply
also i have old version of olarila el capitan and sierra and mojave
i tried it and it gave me Still waiting for root device but i will use new
d
