[Solved] How to make Bluetooth work in Clover.config?
I have to add this to my Info.plist for bluetooth to function. There is no field in Clover Configurator FakeID for Bluetooth. In Devices section there is a Properties box where one can add a EFI string.
I google searched and found the command to extract all DeviceProperties from IOREG but not sure how to extract only the Bluetooth device.
Code in info.plist:
<key>Broadcom2046FamilyUSBBluetoothHCIController_3404</key>
<dict>
<key>CFBundleIdentifier</key>
<string>com.apple.iokit.BroadcomBluetoothHostControllerUSBTransport</string>
<key>IOClass</key>
<string>BroadcomBluetoothHostControllerUSBTransport</string>
<key>IOProviderClass</key>
<string>IOUSBDevice</string>
<key>LMPLoggingEnabled</key>
<false/>
<key>idProduct</key>
<integer>13316</integer>
<key>idVendor</key>
<integer>5075</integer>
</dict>
Command I found on this forum to extract DeviceProperties EFI string from IOREG:
ioreg -lw0 -p IODeviceTree -n efi -r -x | grep device-properties | sed 's/.*/;s/>.*//;' > device-properties.hex
EFI Extracted:
3c3f786d6c2076657273696f6e3d5c22312e305c2220656e636f64696e673d5c225554462d385c223f3ea3c21444f435459504520706c697374205055424c4943205c222d2f2f4170706c652f2f44544420504c49535420312e302f2f454e5c22205c22687474703a2f2f7777772e6170706c652e636f6d2f445444732f50726f70657274794c6973742d312e302e6474645c223ea3c706c6973742076657273696f6e3d5c22312e305c223ea3c646963743ea93c6b65793e4275696c644d616368696e654f534275696c643c2f6b65793ea93c737472696e673e31334531333c2f737472696e673ea93c6b65793e434642756e646c65446576656c6f706d656e74526567696f6e3c2f6b65793ea93c737472696e673e456e676c6973683c2f737472696e673ea93c6b65793e434642756e646c6545786563757461626c653c2f6b65793ea93c737472696e673e42726f6164636f6d426c7565746f6f7468486f7374436f6e74726f6c6c65725553425472616e73706f72743c2f737472696e673ea93c6b65793e434642756e646c65476574496e666f537472696e673c2f6b65793ea93c737472696e673e342e322e362c20436f7079726967687420c2a920323030322d32303134204170706c6520496e632e20416c6c207269676874732072657365727665642e3c2f737472696e673ea93c6b65793e434642756e646c654964656e7469666965723c2f6b65793ea93c737472696e673e636f6d2e6170706c652e696f6b69742e42726f6164636f6d426c7565746f6f7468486f7374436f6e74726f6c6c65725553425472616e73706f72743c2f737472696e673ea93c6b65793e434642756e646c65496e666f44696374696f6e61727956657273696f6e3c2f6b65793ea93c737472696e673e362e303c2f737472696e673ea93c6b65793e434642756e646c654e616d653c2f6b65793ea93c737472696e673e42726f6164636f6d426c7565746f6f7468486f7374436f6e74726f6c6c65725553425472616e73706f72743c2f737472696e673ea93c6b65793e434642756e646c655061636b616765547970653c2f6b65793ea93c737472696e673e4b4558543c2f737472696e673ea93c6b65793e434642756e646c6553686f727456657273696f6e537472696e673c2f6b65793ea93c737472696e673e342e322e363c2f737472696e673ea93c6b65793e434642756e646c655369676e61747572653c2f6b65793ea93c737472696e673e3f3f3f3f3c2f737472696e673ea93c6b65793e434642756e646c6556657273696f6e3c2f6b65793ea93c737472696e673e342e322e3666313c2f737472696e673ea93c6b65793e4454436f6d70696c65723c2f6b65793ea93c737472696e673e636f6d2e6170706c652e636f6d70696c6572732e6c6c766d2e636c616e672e315f303c2f737472696e673ea93c6b65793e4454506c6174666f726d4275696c643c2f6b65793ea93c737472696e673e3541323035333c2f737472696e673ea93c6b65793e4454506c6174666f726d56657273696f6e3c2f6b65793ea93c737472696e673e474d3c2f737472696e673ea93c6b65793e445453444b4275696c643c2f6b65793ea93c737472696e673e31334531333c2f737472696e673ea93c6b65793e445453444b4e616d653c2f6b65793ea93c737472696e673e3c2f737472696e673ea93c6b65793e445458636f64653c2f6b65793ea93c737472696e673e303530313c2f737472696e673ea93c6b65793e445458636f64654275696c643c2f6b65793ea93c737472696e673e3541323035333c2f737472696e673ea93c6b65793e494f4b6974506572736f6e616c69746965733c2f6b65793ea93c646963743ea993c6b65793e42726f6164636f6d3230343646616d696c79555342426c7565746f6f7468484349436f6e74726f6c6c65725f333430343c2f6b65793ea993c646963743ea9993c6b65793e434642756e646c654964656e7469666965723c2f6b65793ea9993c737472696e673e636f6d2e6170706c652e696f6b69742e42726f6164636f6d426c7565746f6f7468486f7374436f6e74726f6c6c65725553425472616e73706f72743c2f737472696e673ea9993c6b65793e494f436c6173733c2f6b65793ea9993c737472696e673e42726f6164636f6d426c7565746f6f7468486f7374436f6e74726f6c6c65725553425472616e73706f72743c2f737472696e673ea9993c6b65793e494f50726f7669646572436c6173733c2f6b65793ea9993c737472696e673e494f5553424465766963653c2f737472696e673ea9993c6b65793e4c4d504c6f6767696e67456e61626c65643c2f6b65793ea9993c66616c73652f3ea9993c6b65793e696450726f647563743c2f6b65793ea9993c696e74656765723e31333331363c2f696e74656765723ea9993c6b65793e696456656e646f723c2f6b65793ea9993c696e74656765723e353037353c2f696e74656765723ea993c2f646963743ea93c2f646963743ea93c6b65793e4e5348756d616e5265616461626c65436f707972696768743c2f6b65793ea93c737472696e673e436f7079726967687420c2a920323030322d32303134204170706c6520496e632e20416c6c207269676874732072657365727665642e3c2f737472696e673ea93c6b65793e4f5342756e646c654c69627261726965733c2f6b65793ea93c646963743ea993c6b65793e636f6d2e6170706c652e696f6b69742e494f4143504946616d696c793c2f6b65793ea993c737472696e673e312e302e303c2f737472696e673ea993c6b65793e636f6d2e6170706c652e696f6b69742e494f426c7565746f6f7468486f7374436f6e74726f6c6c65725553425472616e73706f72743c2f6b65793ea993c737472696e673e312e302e303c2f737472696e673ea993c6b65793e636f6d2e6170706c652e696f6b69742e494f50434946616d696c793c2f6b65793ea993c737472696e673e312e302e303c2f737472696e673ea993c6b65793e636f6d2e6170706c652e696f6b69742e494f55534246616d696c793c2f6b65793ea993c737472696e673e332e322e373c2f737472696e673ea993c6b65793e636f6d2e6170706c652e6b70692e696f6b69743c2f6b65793ea993c737472696e673e382e303c2f737472696e673ea993c6b65793e636f6d2e6170706c652e6b70692e6c69626b65726e3c2f6b65793ea993c737472696e673e382e303c2f737472696e673ea993c6b65793e636f6d2e6170706c652e6b70692e6d6163683c2f6b65793ea993c737472696e673e382e303c2f737472696e673ea993c6b65793e636f6d2e6170706c652e6b70692e756e737570706f727465643c2f6b65793ea993c737472696e673e382e303c2f737472696e673ea93c2f646963743ea93c6b65793e4f5342756e646c6552657175697265643c2f6b65793ea93c737472696e673e5361666520426f6f743c2f737472696e673ea3c2f646963743ea3c2f706c6973743e
EFIStudio is not helping me sort out the devices in the EFI string.
How can I move forward with this or there is no way to get Bluetooth working with EFI string in Clover?
OP-LP3 OverPowered Laptop 17 inch, i7-8750H, 32GB memory, 256GB NvMe stock with windows 10 and added 512GB NvMe Samsung 970 Pro with MacOS 11.2.1, OpenCore 0.6.7.   New Asus Pro WS X299 Sage II intel i9-10980XE 18 core beast Big Sur 11.2.1. OpenCore 0.6.7,  Asus Z390-E i9-9900K 64GB G.Skill Ripjaws Sapphire Pulse RX580, Asus Sabertooth X79 (4) E5-2697 v2 (12 Core), Asus Maximus VIII Hero Alpha i7-7700K 64GB Corsair 2400, Asus Z97-Deluxe i7-4790K, Gigabyte Z77X-UP5-TH i7-3770k, Asus Maximux Formula Special Editions with Rampage Formula Bios conversion, Gigabyte GA-EP35-DS4, GA-EP45-UD3P, GA-G41M-ES2L, GA-Z68X-UD4-B3 and Quo MB.  MAC PRO EARLY 2008, MacPro Late 2012. Asus Notebooks: G51JX i7-720QM, G74SX-XT1 i7-2630QM, Asus G750JX-DB71 Haswell Processor i7-4700HQ GTX 770M 3GB (4).  Dell Laptops D820, D830, XPS M1530 (6), Dell 13-1567 (4), Older processors  i7 (3770K/4770k/6700k/7700K).  Older GFX Cards:  EVGA GT-640, EVGA GTX 760, EVGA GTX 770 (six),
Thanks artur-pt,
Works great. I had it working also when I modified the Info.plist but this Firmware-updator kext is a great idea. It will not however work if its in Clover/kexts/10.x. Has to go in S/L/E and I got a complaint as you have seen about it not being an authorized Kext. I just enabled Developer mode in Clover but not sure if that will work all the time.
The only thing I don't like about the BT-Firmware-uploader kext is that it keeps updating the firmware on ever boot and the kext has to remain in /S/L/E.
So I have to assume there is no way to add EFI DeviceProperties for bluetooth in Clover at this time?
sorry, what's the bluetooth funtion? How work like smt? sr cause stupid quest, sir! :oops: My hackintosher have both wifi and bluetooth with ToledaARPT kext, but sometime boot machine, bluetooth is error "no hardware installer". How to fix it?
