Problem with Installing Mavericks on Gigabyte H97-D3H
Hello Guys..
My PC parts is :
Motherboard : GigabyteGA-H97-D3H
Audio : Realtek® ALC1150 codec - High Definition Audio - 2/4/5.1/7.1-channel - Support for S/PDIF Out
Lan : Intel® GbE LAN chip (10/100/1000 Mbit)
CPU : Intell Core i5 4460 3.2 Haswell.
GPU: Gigabyte GTX 770 2GB Windforce.
Ram : 8 GB.
now i have Mavericks OS X on my USB i make it with myhack
​i want to know what i suppose to do with bios and motherboard after install it , thing like kernal and setup
​and how to do the post-installation correctly to make all thins work (Sound - Internet - Usb - GPU - more...)
​I tried to install it but i must write some flags to open it (-v -x GraphicsEnabler=No), then i used Vietnal tool but the system now working also with flags.
i really ​appreciate your help..if you could...thanks :)
first we don't give any support to others tools .. they have forums like us and should ask for support there..
second u should read , and read a lot about hackintosh , u have a not easy install with that hardware.. anyway
http://Olarila.com/forum/viewtopic.php?f=28&t=1716
start from there .. many useful info about the subject .. here in forum, so good reading
