OpenCore EFI for HP Z420 & Catalina 10.15
hi,
i have a Workstastion HP z420
with cpu : XEON E5-2670 V2
BIOS : 3.96
INTEL IVY-BRIDGE (X79)
Mouse and keyboard are wired
I domwnloaded this EFI from here : https://olarila.com/files/OPENCORE.MOD1/EFI.Opencore.Desktop.HEDT.Sandy.Bridge-E.Ivy.Bridge-E.MOD.zip
After , i drag and drop  EFI in usb pen
when boot it's all ok , but when i stay in Disk Utility i no have mouse & keyboard
where i wrong?
Edited by KUBES
Thanks @MaLd0nfor your availability.
nothing to do...
I followed the guide on the same PC (hp z420)with Windows 10, I created the UTBMap.kext file
I downloaded USBToolBox.kext from github, put it in order as the guide said,
but when I restart from the Pen Drive I always have the same situation. I am attaching the config.plist
config.rar
After several tries, I managed to get it started,
I eliminated in config.plist---- ACPI------patch : this
<key>Base</key>
				<string></string>
				<key>BaseSkip</key>
				<integer>0</integer>
				<key>Comment</key>
				<string>RTC _STA</string>
				<key>Count</key>
				<key>Enabled</key>
				<true/>
				<key>Find</key>
				<data>oAqTU1RBUwE=</data>
				<key>Limit</key>
				<key>Mask</key>
				<data></data>
				<key>OemTableId</key>
				<data></data>
				<key>Replace</key>
				<data>oAqRCv8L//8=</data>
				<key>ReplaceMask</key>
				<data></data>
				<key>Skip</key>
				<key>TableLength</key>
				<key>TableSignature</key>
				<data>RFNEVA==</data>
			</dict>
			<dict>
				<key>Base</key>
				<string></string>
				<key>BaseSkip</key>
				<key>Comment</key>
				<string>EUSB to EH01</string>
				<key>Count</key>
				<key>Enabled</key>
				<true/>
				<key>Find</key>
				<data>RVVTQg==</data>
				<key>Limit</key>
				<key>Mask</key>
				<data></data>
				<data></data>
				<key>Replace</key>
				<data>RUgwMQ==</data>
				<data></data>
				<key>Skip</key>
				<data></data>
			</dict>
			<dict>
				<key>Base</key>
				<string></string>
				<key>BaseSkip</key>
				<key>Comment</key>
				<string>USBE to EH02</string>
				<key>Count</key>
				<key>Enabled</key>
				<true/>
				<key>Find</key>
				<data>VVNCRQ==</data>
				<key>Limit</key>
				<key>Mask</key>
				<data></data>
				<data></data>
				<key>Replace</key>
				<data>RUgwMg==</data>
				<data></data>
				<key>Skip</key>
				<data></data>
			</dict>
			<dict>
				<key>Base</key>
				<string></string>
				<key>BaseSkip</key>
				<key>Comment</key>
				<string>CUU0</string>
				<key>Count</key>
				<key>Enabled</key>
				<true/>
				<key>Find</key>
				<data>cA1DUFVTQ0swAENVVTA=</data>
				<key>Limit</key>
				<key>Mask</key>
				<data></data>
				<data></data>
				<key>Replace</key>
				<data>AAAAAAAAAAAAAAAAAAA=</data>
				<data></data>
				<key>Skip</key>
			</dict>
			<dict>
				<key>Base</key>
				<string></string>
				<key>BaseSkip</key>
				<key>Comment</key>
				<string>CUU1</string>
				<key>Count</key>
				<key>Enabled</key>
				<true/>
				<key>Find</key>
				<data>cA1DUFVTQ0sxAENVVTE=</data>
				<key>Limit</key>
				<key>Mask</key>
				<data></data>
				<data></data>
				<key>Replace</key>
				<data></data>
				<key>Skip</key>
			</dict>
			<dict>
				<key>Base</key>
				<string></string>
				<key>BaseSkip</key>
				<key>Comment</key>
				<string>CUU2</string>
				<key>Count</key>
				<key>Enabled</key>
				<true/>
				<key>Find</key>
				<data>cA1DUFVTQ0syAENVVTI=</data>
				<key>Limit</key>
				<key>Mask</key>
				<data></data>
				<data></data>
				<key>Replace</key>
				<data></data>
				<key>Skip</key>
			</dict>
			<dict>
				<key>Base</key>
				<string></string>
				<key>BaseSkip</key>
				<key>Comment</key>
				<string>CUU3</string>
				<key>Count</key>
				<key>Enabled</key>
				<true/>
				<key>Find</key>
				<data>cA1DUFVTQ0szAENVVTM=</data>
				<key>Limit</key>
				<key>Mask</key>
				<data></data>
				<data></data>
				<key>Replace</key>
				<data></data>
				<key>Skip</key>
			</dict>
and putting usbmap and usbtool worked fine...
I managed to install Catalina.
Now work :audio, mouse, keyboard, Lan.
How do I go about configuring an Nvidia Quadro k2200 ? Thank you .
