pernacabeluda Posted November 29, 2014 Author Posted November 29, 2014 Probably missing FakeSMC http://Olarila.com/forum/viewtopic.php?f=28&t=1716 How to copy boot from USB http://Olarila.com/forum/viewtopic.php?f=28&t=3405&p=33648#p33648 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
cool_recep Posted December 13, 2014 Posted December 13, 2014 10.10.2 is coming. Please no GenericUSBXHCI.kext. And please default Kernel PM Patch enabled. I can pay for a custom release.
kbrall Posted January 13, 2015 Posted January 13, 2015 Perna, preciso de ajuda e gostaria de saber se consegue ajudar. tenho um HP Pavilion DV6000 e estou querendo fazer ele de cobaia para a instalação o OS X. Li diversos posts e tutoriais, inclusive baixei os seus arquivos, porem, estou com duas duvidas que nao consegui realizar: 1- Não consigo colocar minha BIOS em modo AHCI, não ha essa opção e, 2- O arquivo do do USB bootloader é so colocar no pendrive, precisa de alguma modificação? Abrços
artur-pt Posted January 13, 2015 Posted January 13, 2015 olá talvez se tiveres problemas tentares alguma destas kext http://Olarila.com/files/10.8/AHCI/ e precisas de ler .. pelo menos o guia de uso desta imagem.. bom hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
pernacabeluda Posted February 3, 2015 Author Posted February 3, 2015 I won't. This image is intended for people who don't have a working OS X. Once you have any version running you can easily create an updated installer, there are guides all over the internet, even in this forum. http://Olarila.com/forum/viewtopic.php?f=28&t=4632 http://Olarila.com/forum/viewtopic.php?f=36&t=4650 http://Olarila.com/forum/viewtopic.php?f=28&t=4932 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
editor Posted June 26, 2015 Posted June 26, 2015 hai ....every one. installed "OS X Yosemite 10.10 (14A389) bootable USB for Intel PCs" successfully .... but i face two problems... 1st.....no audio.. 2nd.....usb mouse not working.... any one pls help me with exact procedure ....? my system config ----------------------- Processor - 3.89 GHz intel core i7 4770k Motherboard -Gigabyte z87x ud 4h
mendietinha Posted June 27, 2015 Posted June 27, 2015 voodoohda, generic usb 3.0, use correct smbios. Se quando viaja faz o que quer, quando viajar, não leve a mulher ---- No PM support. Use the forum. . Lenovo Core I5 6200U 12Gb 256Gb HD520 (macOS 13.7.6 - macOS 26) OC Ryzen 7 5700X 32Gb 2Tb nvme RTX 3060TI 8Gb (W11)
editor Posted June 27, 2015 Posted June 27, 2015 Thank you for ur kind informetion ..... i tried this way... first i use system info... then i find my kext from here "http://Olarila.com/kexts/" i confused because 9 kext available for download which is the corrrect kext i need pls help me....??
mendietinha Posted June 27, 2015 Posted June 27, 2015 perhaps here> http://sourceforge.net/projects/voodoohda/ Se quando viaja faz o que quer, quando viajar, não leve a mulher ---- No PM support. Use the forum. . Lenovo Core I5 6200U 12Gb 256Gb HD520 (macOS 13.7.6 - macOS 26) OC Ryzen 7 5700X 32Gb 2Tb nvme RTX 3060TI 8Gb (W11)
editor Posted June 27, 2015 Posted June 27, 2015 again thank u mr. mendietinha.... "VoodooHDA kext" not working for me
