pernacabeluda Posted November 25, 2014 Author Posted November 25, 2014 I won't build an updated installer for now, the USB 3.0 issue needs more testing and feedback. Also, I read people are having problems with the 10.10.1 installer http://www.projectosx.com/forum/index.php?s=&showtopic=2562&view=findpost&p=43302 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
mendietinha Posted November 25, 2014 Posted November 25, 2014 usb3 kext works perfectly here. Se quando viaja faz o que quer, quando viajar, não leve a mulher ---- No PM support. Use the forum. . Lenovo Core I5 6200U 12Gb 256Gb HD520 (macOS 13.7.6 - macOS 26) OC Ryzen 7 5700X 32Gb 2Tb nvme RTX 3060TI 8Gb (W11)
cool_recep Posted November 25, 2014 Posted November 25, 2014 usb3 kext works perfectly here. I have done dozens of installs and all of them stalled. Removed Kext and I was good to go.
quest Posted November 29, 2014 Posted November 29, 2014 works flawless but when i install the clover bootloader and reboot the system it gets stuck on the spinning wheel tho it boots flawless from the usb i tried several times reinstalling the OS and got tired, ok is there a way to get the bootloader from this installer booting from the usb is kinda pain and it even makes the system slow when the OS is trying to read the 6gb files and don't want to waste 16gb of space any help will be grateful. Thank you
pernacabeluda Posted November 29, 2014 Author Posted November 29, 2014 Probably missing FakeSMC http://Olarila.com/forum/viewtopic.php?f=28&t=1716 How to copy boot from USB http://Olarila.com/forum/viewtopic.php?f=28&t=3405&p=33648#p33648 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
cool_recep Posted December 13, 2014 Posted December 13, 2014 10.10.2 is coming. Please no GenericUSBXHCI.kext. And please default Kernel PM Patch enabled. I can pay for a custom release.
kbrall Posted January 13, 2015 Posted January 13, 2015 Perna, preciso de ajuda e gostaria de saber se consegue ajudar. tenho um HP Pavilion DV6000 e estou querendo fazer ele de cobaia para a instalação o OS X. Li diversos posts e tutoriais, inclusive baixei os seus arquivos, porem, estou com duas duvidas que nao consegui realizar: 1- Não consigo colocar minha BIOS em modo AHCI, não ha essa opção e, 2- O arquivo do do USB bootloader é so colocar no pendrive, precisa de alguma modificação? Abrços
artur-pt Posted January 13, 2015 Posted January 13, 2015 olá talvez se tiveres problemas tentares alguma destas kext http://Olarila.com/files/10.8/AHCI/ e precisas de ler .. pelo menos o guia de uso desta imagem.. bom hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
pernacabeluda Posted February 3, 2015 Author Posted February 3, 2015 I won't. This image is intended for people who don't have a working OS X. Once you have any version running you can easily create an updated installer, there are guides all over the internet, even in this forum. http://Olarila.com/forum/viewtopic.php?f=28&t=4632 http://Olarila.com/forum/viewtopic.php?f=36&t=4650 http://Olarila.com/forum/viewtopic.php?f=28&t=4932 -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE
editor Posted June 26, 2015 Posted June 26, 2015 hai ....every one. installed "OS X Yosemite 10.10 (14A389) bootable USB for Intel PCs" successfully .... but i face two problems... 1st.....no audio.. 2nd.....usb mouse not working.... any one pls help me with exact procedure ....? my system config ----------------------- Processor - 3.89 GHz intel core i7 4770k Motherboard -Gigabyte z87x ud 4h
mendietinha Posted June 27, 2015 Posted June 27, 2015 voodoohda, generic usb 3.0, use correct smbios. Se quando viaja faz o que quer, quando viajar, não leve a mulher ---- No PM support. Use the forum. . Lenovo Core I5 6200U 12Gb 256Gb HD520 (macOS 13.7.6 - macOS 26) OC Ryzen 7 5700X 32Gb 2Tb nvme RTX 3060TI 8Gb (W11)
editor Posted June 27, 2015 Posted June 27, 2015 Thank you for ur kind informetion ..... i tried this way... first i use system info... then i find my kext from here "http://Olarila.com/kexts/" i confused because 9 kext available for download which is the corrrect kext i need pls help me....??
mendietinha Posted June 27, 2015 Posted June 27, 2015 perhaps here> http://sourceforge.net/projects/voodoohda/ Se quando viaja faz o que quer, quando viajar, não leve a mulher ---- No PM support. Use the forum. . Lenovo Core I5 6200U 12Gb 256Gb HD520 (macOS 13.7.6 - macOS 26) OC Ryzen 7 5700X 32Gb 2Tb nvme RTX 3060TI 8Gb (W11)
editor Posted June 27, 2015 Posted June 27, 2015 again thank u mr. mendietinha.... "VoodooHDA kext" not working for me
