I can boot into Clover without issue.
When I try to run the installer, it runs but hangs up at the line:[iOBluetoothHCIController][start] -- Completed
After that line, I get a cursor return to the next line, then it does nothing. Ideas on what's going on here?
Also, checking my former Windows 8.1 install, it is now corrupted. I'm fine with wiping out the windows install, and re-installing Windows later, but would like to get OSX installed. My laptop right now is basically a $800 paper weight.
is a graphics problem .. read carefully the image guide.. and do what is write there
I gave up... couldn't fix it.... Had to take the computer back to Best Buy to get Windows replaced (didn't come with any boot disks).
mac os x is developed exclusively for mac
hack mac os x .. is another bed story
hack mac os x is 99% of reading, googling, persistency and 1% of luck u have compatible hardware like a real mac...
about the luck.. u always need the other 99%
if is not ur case .. hack mac os x.. maybe is not for u...
