My laptop have two VGA card: Intel HD Graphics 1st Gen and Nvidia GT435M with Optimus ( cant disable from bios) ! I try disable Nvidia but its not working. So i hope someone help me disable Nvidia card from dsdt and help me not to add Natit.kext each startup ! And how i can use fn key to up/down volumes, i try add kext but its not effective
System Info
Mac OS 10.9.4
Asus N43jm-vx039
Intel Core i5 M480 2,66GHz
Nvidia GT435m with optimus mode
realtek ALC269vb
14inch LCD-led 1366x768
DSDT.aml (1).zip
To disable nVidia try to insert
\_SB.PCI0.PEG1.GFX0._OFF ()
into \_SB.PCI0._INI
    Scope (_SB.PCI0)
       Method (_INI, 0, NotSerialized)
           Store (0x07D0, OSYS)
If it turns on again after sleep, insert it also into _WAK
    Method (_WAK, 1, Serialized)
       WAK (Arg0)
