I'm deleting ARG0, trying to compile - everything looks good, the only thing left to do is to fix PARSEOP_ZERO.
I'm deleting a bunch of Zero's, trying to compile - everything goes bat$h1t crazy!
Trying to fix both errors in reverse order, getting the same results...
The compiler i'm using is pretty updated (iasl_20140424_64). What am i doing wrong??
Here's my dsdt: http://www.sendspace.com/file/1o8qp4
Thanks in advance
i work a little in ur dsdt
so.. no errors
if u have external error is from ur graphics present in ssdt tables.. just delete that lines
dsdt.dsl.zip
Thank you for quick response! But how did you fix it?
This dsdt isn't finished yet, i still need to apply many other patches so i have to know how to fix those errors.
if u apply the correct patches .. don't give u any errors
the errors are already in the extracted dsdt
The patches i applied (DTGP, IRQ’s, SMBUS and LPC) didn't fix any of those 2 errors, did i miss anything?
what errors ?
i send u a dsdt without error
is in that one u apply the patches
Thank you for your support, but I want to learn how to fix those errors, i don't need to fix this particular dsdt.
reading acpi specs
http://acpi.info/spec.htm
is not with patch u remove the errors
the patch have no errors.. it have adress and device name and methods to apply in the correct place
u can try see the diff between the 2 files
i answer u in another post u have
that are external method present in ur ssdt tables .. is ur graphics
