I have an acer aspire 7730zg with
cpu = pentium 4 t3400
chipset =
mobile intel pm45
wifi = atheros AR928X (AR5B91)
Ethernet = BCM5764M ( Broadcrom nextExtreme GigaBit Ethernet)
Ethernet and wifi are not working
(I also need the modified ketxt)
for the ethernet try this
http://www.insanelymac.com/forum/topic/247470-bcm5722-bcm5754m-bcm5755m-bcm5787m-and-bcm5906m-nic-driver-3264-bit/
wifi
                       Store (Package (0x12)
                               "AAPL,slot-name",
                               Buffer (0x08)
                                   "AirPort"
                               "device-id",
                               Unicode ("*"),
                               "device_type",
                               Buffer (0x08)
                                   "AirPort"
                               "model",
                               Buffer (0x33)
                                   "Atheros 9285 802.11 b/g/n Wireless Network Adapter"
                               "subsystem-id",
                               Buffer (0x04)
                                    0x8F, 0x00, 0x00, 0x00
                               "subsystem-vendor-id",
                               Buffer (0x04)
                                    0x6B, 0x10, 0x00, 0x00
                               "compatible",
                               Buffer (0x0B)
                                   "pci168c,2a"
                               "IOName",
                               Buffer (0x0B)
                                   "pci168c,2a"
                               "name",
                               Buffer (0x0B)
                                   "pci168c,2a"
                           }, Local0)
                       Return (Local0)
Thanks , will try it out.
Just to make sure I understood correctly , this is what I am supposed to do:
The above script is a patch for my dsdt.
I will save it as a txt file (e.g acer.txt)
I will extract my dsdt using dsdt editor or something similar.
I will apply the patch to the dsdt
recompile the dsdt
save it as dsdt.aml (e.g on my root directory)
refer to in in chameleon config file during boot (org.chameleon.Boot.plist ->DSDT=hd(0,1)/DSDT.aml)
Is this correct ?
basicly yes.. is that
but the original patch is one of this .. after only copy there that dsm method
must know where is the device of the wifi
http://Olarila.com/Patches/Misc/Atheros%209285%20(no%20WLAN).txt
no wlan device
http://Olarila.com/Patches/Misc/Atheros%209285.txt
