please help, my dsdt has only a few error but I can not fix
Hello there,
I am running 10.9.2 chameleon 2.2 bootloader, on Toshiba L855 Laptop with fakesmc nullcpupowermanagement.
but I really want to have dsdt working so my laptop can go sleep and wake up properly.
I extract my dsdt and there are a few error but I can not fix it.
Can some expert fix my dsdt? Thanks very much
warning 1447, I change zero to 0x00000000 as DWORD just like others but warning remain same
Remark 6265 I change _T_1 to _TA_1 and _T_0 to _TA_0 so it does not use compiler
reserved word but I get more error after change it.
Hardware specs:
Toshiba Satellite L855-S5383 Notebook PC - 8GB,
Intel Core i7-3630QM 2.4GHz, 8GB DDR3, 240GB SSD, 15.6" Display
video intel hd 4000
Audio (i used Voodoo 2.8.4 working)
WLAN Broadcom 4331 working
ethenet ALXEthernet 1.02 (working)
dsdt_toshiba_extract_from_Toshiba_OSX10.9.2_running_NullCPUManagement.aml.zip
dsdt_error_msg.tiff
Thanks so much to fix my dsdt. all the error/warning/remark are all gone except line 34 name already exist in scope (\TNOT).
I remove line 34 to get rid of \TNOT and compiler is ok with new DSDT.dsl
I then save the binary file as DSDT.aml
if I use DSDT.asm and recompile again, I will get the error line 34 again. Will this be a problem for DSDT.aml?
or it is something can be ignored?
Again, Thanks so much to fix dsdt.
try this:DSDT.aml.zip
Thanks a lot. No more compiler error any more. :D
Ok, I remove NullCPUPower... FakeSMC and put DSDT.aml under root. I can see bootloader use the new DSDT now. how ever at the end I still get KP at AppleIntelCPUPowerManagement. I have try -v -f -x
I notice that you add this Method.
Store (Package (0x02)
"device-id",
Buffer (0x04)
0x44, 0x1E, 0x00, 0x00
}, Local0)
Return (Local0)
I see some people on the forum (the link your provide) use Buffer(0x0D), or different ID(3a18 or 1e57). how do I know which is my device ID for my Toshiba laptop?
i dump ioreg tree. any hint how to match the device ID?
ioreg_toshiba.txt.zip
artur-pt, you're so smart. I didn't patch AICM. follow your link and a few more click, I found a patch for 10.9.2. Install the patched AICP, boom!
No more KP. Original I was reading some post and misunderstood that AICP patch is no need because of
"Chameleon boot loader can generate SSDTs with P and C states automatically, simply enable the options"
and I also found some patch was for 10.7 or 10.8 so I was hesitated to install the patch. But I am good right now.
I am not sure if the sleep work. when I click sleep, screen goes blank until I touch the KB or anything.
HDD light, BT light seems still
on after sleep. so I am checking more on sleep.
Thankkkkkk you so much. You are super!
in the same link u have a script to generate ur SSDT.aml .. to have the correct states for ur cpu
when u have it
chameleon
DropSSDT=Yes
P and C-States=No
then probably u have cpu power management working correctly
Mac.tiffthanks for the hint. After I add SSDT, the sleep symptom seems the same. I went ahead to install HWSensors. It shows only CPU information. I wasn't sure if it is correct so I install HWSensors on real mac. there are way more information on real mac. so I guess I probably miss a lot of info on Toshiba L855. here is the screen shot of both. Any idea how I can fix it?
I do not have battery working correctly, is it going to be a problem with sleep?
Toshiba.tiff
