Hello,
Artur was kind enough to help me get started with editing dsdt but now I have 2 problem.
Apr 17 18:11:30 localhost kernel[0]: Kext com.apple.driver.AppleIntelHD4000Graphics - library kext com.apple.iokit.IOAcceleratorFamily2 not found.
Apr 17 18:11:25 localhost com.apple.launchd[1]: *** launchd[1] has started up. ***
Apr 17 18:11:30 localhost kernel[0]: Can't load kext com.apple.driver.AppleIntelHD4000Graphics - failed to resolve library dependencies.
Apr 17 18:11:30 localhost kernel[0]: Kext com.apple.driver.AppleIntelHD4000Graphics failed to load (0xdc00800e).
Apr 17 18:11:30 localhost kernel[0]: Failed to load kext com.apple.driver.AppleIntelHD4000Graphics (error 0xdc00800e).
For graphics I did not change dsdt just proper smbios and "InjectCapriFB=3" in chameleon.boot.plist and it requires -x.
For audio I follow http://www.projectosx.com/forum/index.php?showtopic=465 but AppleHDA does not load.
Thank you for any suggestion.
Regards,
Regards,
try this one
it have kg-platform-id = 9
no need to inject in chameleon it was already in dsdt
really don't understand what u try to do with audio ?.. u are trying patch the applehda.. if so forget it..
u must find ur audio codec and try to use a already patched kext.. and know what that kext need for layout id.. now the dsdt is defined for layout 12 for applehda.
Ah what happened was I didn't know to add to dsdt not change. I look for igpu and gfx in my original but it wasnt there but I see you added igpu. Also I must remove FrameBufferCapri in order to boot.
Anyways I tried to patch applehda because I cannot find patched alc3202. I installed applehdadisabler and voodoohda but it says no voodoohda devices found.
Regards,
Regards,
send new ioreg with that dsdt
and post pic from system related to graphics
ur native resolution is 1366x768 ?
try this one
u never have working graphics with the several ig-platform-id ?
if loads only that don't work
no qe/ci
u must find the right platform-id
Oh I thought I have to convert hex.
I try all the ones with 64mb ram: 2, 3, 8, 9 but the System>Graphics always shows 0x0009?
So i remove dsdt from /Extra and 1366x768 resolution still loads even with no dsdt or chameleon.boot.plist GraphicsMode or injection. How can that happen? I have to boot from USB btw.
Regards,
the revision id is not.. platform-id
u see that with ioreg
So I tried 0-9 and AB for platdorm-id. FrameBufferCapri has proper device-id (01668086). But framebuffer causes panic even with safeboot.
Regards,
so... now is good.. that is it must say 1024 mb
now u have qe/ci
