Hi,
I am trying to mke this laptop run Mavericks. I am jumping out from one forum to another but still can't fix the problems I have.
1. System freezes. It happened couple of times
a. Inserting USB device (not always)
b. Running IoReg
c. During Web browsing
d. No apparent reason.
I just can’t find the real reason.
2. Audio doesn't work. It works if I use patched dsdt and VoodoHDA but sound quality is not good and I hear noise from headphones.
I am really tired. Last night I stayed till 5 AM to find solutions which I couldn't. I really want to fix it. I have attached everything I have for now
https://dl.dropboxusercontent.com/u/157304/My%20Files.zip
Extracted Folder
This folder has my original unpatched DSDT and SSDT tables extracted from Windows with AIDA
Patched Folder
This folder has my patched files that I use right now. It has patched DSDT, SSDT.aml which is created with ssdtPRGEN and SSDT-*.aml files. I have patched SSDT-4.aml for brightness.
Codec Folder
This folder has my CodecDump.zip extracted with Ubuntu. I have also added converted txt and svg files.
Settings Folder
This folder has my IoReg created with DSDT=no option and chameleon settings.
My Specs
Computer: DELL Inspiron 5437
CPU: Intel Core i5-4200U (Haswell ULT, C0/D0)
2300 MHz (23.00x100.0) @ 1596 MHz (16.00x99.8)
Motherboard: DELL 0DM7G0
Chipset: Intel Lynx Point-LP (Premium)
Memory: 4096 MBytes @ 798 MHz, 11.0-11-11-28
- 4096 MB PC12800 DDR3 SDRAM - Hynix (Hyundai) HMT451S6AFR8A-PB
Graphics: Intel Haswell-MB ULT GT2 - Integrated Graphics Controller [C0/D0] [DELL]
Intel HD Graphics 4600, 1820430 KB
Drive: WDC WD10JPVX-75JC3T0, 976.8 GB, Serial ATA 6Gb/s @ 6Gb/s
Drive: TSSTcorp DVD+-RW SU-208CB, DVD+R DL
Sound: ALC283
Network: Atheros Communications AR9565 Wireless Network Adapter
Network: RealTek RTL8106E-US
I am really tired and I am sorry if I sound whining. I just want to fix this laptop. I will really appreciate if you give me a hand. Thanks very much.
hack mac os x is not easy..
DSDT.zip
only use the ssdt generated by the script
dropssdt=yes
p and c-states=no
Hi,
b. Running IoReg
Extracted Folder
Patched Folder
Codec Folder
Settings Folder
My Specs
Sound: ALC283
Delete VoodooHDA.kext, HDAEnable.kext, HDAdisble.kext if available. Install kext AppleHDA, copy DSDT.aml to Extra then reboot. Feedback hope this help
Archive.zip
