GA P35-DS3R 2.0 Mavericks 10.9.2 Clover shutdown problem
Hi,
Ok it's not the latest motherborad. I'm using it for years without problems. And I must humbly say I'm not a beguinner.
Now for the first time since mavericks I can't manage to let it shutdown. The fan will alwas remain spinning. It drives me almost crazy. Every other thing works perfect.
I use the standard kexts plus the ones recommmended from Mald0n for this board some years ago. org.plist ( I do not rememeber the right name under clover) was created by the clover installer and modified to simulate a MacPro3.1. My dsdt ist a original one from Mald0n.
Can someone point me to the light :-( ?
675-dsdt.GA P35-DS3-F14 by MaLd0n.zip
must be something wrong in clover config...
u test with chameleon ?
if with chameleon no problems.. u know is a problem with clover config.. u can try also this
http://clover-wiki.zetam.org/Configuration/ACPI#DSDT-/-Fixes
there is a fix to shutdown
Hi Artur-pt,
T.v.m. for your quick answer. I understand I can add
XXXXXXXXXXXXXXXXXXXXXXXXXXX
Fixes
FixShutdown_0004
in my xxxorg.plist.
About installing Chameleon, I was a little reluctant beacause i do not really know how to manually erase Clover in a consistent manner from my hdisk. Just erease the boot file and EFI-Folder?
Last but not least. Let my say I have been reading your comments and solutions with admiration many, many times und got something like a warm heart when I saw you were contacting me directly this time :-)
like in installer , u can have both boot loaders in same hd
clover installer must have enable pbr option
and rename the file boot from chameleon install to boot1
must have a Extra folder with chameleon config
in boot when u hit 1
it goes to chameleon boot loader
if u don't do nothing it use Clover to load the OSX
http://clover-wiki.zetam.org/What-is-what#PBR-sector
Hi artur-pt,
Did as you said. The first sugestion to integrate the shutdown in the xxxorg.plist did not work. But the second yes. This is, chameleon does very well (as always ! This is my experience. In my other computer as well !)
The only thing is I do not know to which stage should I hit 1 (or not) when keeping Clover as well as you suggested. Can you explain?
Obrigado
if u have the 2 loaders installed, when u power on u hit 1 to load boot1 file and go to chameleon.
if u don't do nothing is clover boot process
u test it
