Hello.
I'm trying to install Big Sur but appears imposible. I have no problem installing high sierra, but I need a more actual version. I think probably my computer is not avaible to hack :S. The problem is after booting from the USB (done with balena and olarila iso image). I choose the USB, but then, doesnt apper the Olarila Menu (like on high sierra), just appear 4 incons, one of them is install Big sur OS (with picture of an apple). But when I pick on it, doenst arrive to the OS instalation. Just a screen full of errors and I have to restart the computer.
It s very frustrating, because High Sierra works perfectly, but I tried all versions after and I coulnot open anyone. Do you know what the hell could be? I have an ACER F5-771G.
qFpgNY3
DbKsV2C
Edited by Carlos Vico
Motherboard: MSI B760
CPU: Intel core i9-14900KF
GPU: Radeon RX6800
RAM: FURY Beast 2x32 Gb
what processor?
Intel Core i5-7200U (2 x 2.5 GHz)
NVIDIA GeForce GTX 950M
Intel HD Grafics 620 (there s no drivers for de nvidia I think)
Ram 2x8GB DDR4
54 minutes ago, Carlos Vico said:
It s the same with the others more advanced
Ventura
FWCPQwp
ZW433w1
Monterey
1zD9WHC
QDdS7jx
I dont have pictures of all, but I tried with Catalina and Mojave and It was the same. Just I arrived at High Sierra when I could install without problemas.
The menu choosing the installation is completely different. I looked for information because It looks like my computer is able to be installed all of the OS but I found nobody with the same error:(
GPU: Radeon RX6800
-NoteBook KabyLake Download HERE
What does that mean? Isnot that the EFI folder that I have to replace when I have installed OS? My problem is before the installation. I cannot run the installer
GPU: Radeon RX6800
