Administrators MaLd0n Posted February 27, 2023 Administrators Share Posted February 27, 2023 A Lilu plug-in for dynamic power management data injection. Link HERE Notes This repository must be compiled with latest Lilu and MacKernelSDK, otherwise the compilation will fail! Note: Debug version of Lilu.kext and MacKernelSDK project folder should be put in the same folder as CPUFriend! And debug versions of Lilu and CPUFriend should also be used together when debugging! Configuration This kext is most likely not required when the CPU is natively supported by XNU (macOS kernel). In case of necessity, please see Instructions for configuration. Credits Apple for macOS vit9696 for Lilu.kext and various helps PMheart for writing the software and maintaining it -Guides and Tutorials HERE -Hackintosh Tutorial Database - HERE -The largest EFI folder collection for Hackintosh HERE -Support Olarila Vanilla Hackintosh by making a donation HERE -Professional Consulting for macOS Hackintosh since 2006 HERE Link to comment Share on other sites More sharing options...
