Asus N53SN-SZ139V Help me out please!!
[attachment=0]dsdt.fariel23.zip[/attachment]
thank u for the dsdt however when i use it it can not find my wifi. its says WI-FI CARD NOT INSTALLED
This topic mentions 0x002b168c in the title
http://osx86.co/f36/atheros-ar9285-0x002b168c-fix-for-snow-leopard-t6662/
The patch is almost the same you are using, but it has Buffer () {0x2A, 0x00, 0x00, 0x00} for device-id, instead of Unicode ("*") like you are using. Maybe faking the 2a ID makes 2b cards work better, you can try that.
can u please make a dsdt patch for me. so that i can patch cause i dont know how to do it..
by the way i take a screenshot of my wlan@0 so u can see..
WLAN@0 ScreenShot.zip
Just open your dsdt.aml with DSDT Editor, search for "WLAN", replace Unicode ("*") by Buffer () {0x2A, 0x00, 0x00, 0x00}, compile and save.
Or use this
into method label _DSM parent_label WLAN remove_entry;
into device label WLAN insert
begin
{\n
   Store (Package (0x0C)\n
       {\n
           "AAPL,slot-name", \n
           Buffer (0x08)\n
           {\n
               "AirPort"\n
           }, \n
           "device-id", \n
           Buffer (0x04)\n
           {\n
               0x2A, 0x00, 0x00, 0x00\n
           }, \n
           "device_type", \n
           Buffer (0x08)\n
           {\n
               "AirPort"\n
           }, \n
           "model", \n
           Buffer (0x34)\n
           {\n
               "Atheros 9285 8802.11 b/g/n Wireless Network Adapter"\n
           }, \n
           "subsystem-id", \n
           Buffer (0x04)\n
           {\n
               0x8F, 0x00, 0x00, 0x00\n
           }, \n
           "subsystem-vendor-id", \n
           Buffer (0x04)\n
           {\n
               0x6B, 0x10, 0x00, 0x00\n
           }\n
       }, Local0)\n
   Return (Local0)\n
end
Or use this
begin
{\n
       {\n
           Buffer (0x08)\n
           {\n
               "AirPort"\n
           }, \n
           "device-id", \n
           Buffer (0x04)\n
           {\n
           }, \n
           "device_type", \n
           Buffer (0x08)\n
           {\n
               "AirPort"\n
           }, \n
           "model", \n
           Buffer (0x34)\n
           {\n
           }, \n
           "subsystem-id", \n
           Buffer (0x04)\n
           {\n
           }, \n
           Buffer (0x04)\n
           {\n
           }\n
       }, Local0)\n
   Return (Local0)\n
end
just try that but again no luck connection failed ????
Is it a N router? I've read about problems connecting to N routers with Atheros 9285.
as us saw on the youtube video i try a few others and could also no connect so i think there most be something else
i wil do a fresh install with the dsdt that mald0n did for me i wil let u know how that go
im now @ the setup screen and using dsdt from mald0n i see there is no WI-FI No Hardware Installed
i dont know why on the setup i can connect without problem and the when the installation finish i CAN'T connect???????
maybe this help i was using a lion dvd call " LION PC FIX DVD" i convert that to my usb stick. do u think that may be the issue???
should i use the original lion installer from apple store with my bootloader and extra folder with the dsdt.aml?
Maybe this DVD you are using has a patched kext for the wireless card in its base system, but it installs the original one.
Try to copy IO80211Family.kext from DVD do HD (repair permissions).
Also check if /System/Library/SystemConfiguration/Apple80211Monitor.bundle is present in the DVD, and wich SMboardproduct it uses in SMBIOS (or is used in the boot CD).
i have a good news my wifi is now working no more problem on that side i find out i needed to copy my extra folder AFTER the installation . using the lion pc fix cause with the original lion from apple store did not work
so thank u very much oldnapalm helping me out
your dsdt patches worked u r a genie
god bless u
so now im running a fresh installation
thank u very much for ur time
The DualLink patch is simple, like GMA950
into device name_adr 0x00020000 insert
begin
{\n
   Store (Package (0x02)\n
       {\n
           "AAPL00,DualLink",\n
           Buffer (0x04)\n
           {\n
               0x01, 0x00, 0x00, 0x00\n
           }\n
       }, Local0)\n
   Return (Local0)\n
end
Hello,
I applied this fix as well (fixed greenish screen for me), but I am getting artifacts randomly. Rectangle/bar shaped artifacts...
Does it have to do with the dualLink fix? Or is there another fix for this?
This is the exact code in my dsdt:
Device (GFX0)
           Name (_ADR, 0x00020000)
           Method (_DOS, 1, NotSerialized)
               Store (And (Arg0, 0x07), DSEN)
               If (LEqual (And (Arg0, 0x03), Zero))
                   If (CondRefOf (HDOS))
                       HDOS ()
                       "AAPL00,DualLink",
                       Buffer (0x04)
                   }, Local0)
               Return (Local0)
Running: 10.7.1
Mobo: Alienware M14xR1
Chipset: Intel HM67
Intel i7 2720QM / Intel HD 3000
Hello,
Device (GFX0)
                       HDOS ()
                       "AAPL00,DualLink",
                       Buffer (0x04)
                   }, Local0)
               Return (Local0)
Running: 10.7.1
Chipset: Intel HM67
it got to be the chameleon boot loader try chimera. i notice that also only on the installer the artifacts with the chameleon bootloader but not with chimera. now I'm using the latest chameleon and is working fine. hoop u can get it right . try openGL View do some test and see if u get artifacts and let us know. good luck
Try to enable it in Windows and reboot into Mac OS.
i just try that now it recognize but can't send files or receive file.
this is on the system information:
Apple Bluetooth Software Version: 2.5.0f17
Hardware Settings:
Address: e0-b9-a5-45-6f-cd
Manufacturer: Unknown
Name: Farriel’s MacBook Pro
Firmware Version: 5.39321 (5.39321)
Bluetooth Power: On
Discoverable: Yes
Vendor ID: 0
Product ID: 0x7fff
HCI Version: 5 (0x5)
HCI Revision: 39321 (0x9999)
LMP Version: 5 (0x5)
LMP Subversion: 39321 (0x9999)
Device Type (Major): Computer
Device Type (Complete): Mac Portable
Composite Class Of Device: 3801356 (0x3a010c)
Device Class (Major): 1 (0x1)
Device Class (Minor): 3 (0x3)
Service Class: 464 (0x1d0)
Peer to Peer Supported: Yes
Services:
Bluetooth File Transfer:
Folder other devices can browse: ~/Public
Requires Authentication: Yes
State: Enabled
Bluetooth File Exchange:
Folder for accepted items: ~/Downloads
Requires Authentication: No
When other items are accepted: Ask
When PIM items are accepted: Ask
When receiving items: Prompt for each file
State: Enabled
Devices (Paired, Favorites, etc):
LG KP500:
Address: 00-22-a9-64-a2-cb
Type: Mobile Phone
Firmware Version: 0
Services: Dialup Networking, HFP Audio Gateway, Advanced audio source, Object Push, Phonebook Access PSE, OBEX File Transfer, Serial Port 1, HSP Audio Gateway
Paired: Yes
Favorite: No
Connected: No
Manufacturer: Broadcom (0x4, 0x410b)
Vendor ID: 0x0f
Product ID: 0
EDR Supported: Yes
eSCO Supported: Yes
Incoming Serial Ports:
Bluetooth-PDA-Sync:
RFCOMM Channel: 3
Outgoing Serial Ports:
Bluetooth-Modem:
Address:
RFCOMM Channel: 0
and this on the usb tab:
Bluetooth USB Host Controller:
Product ID: 0x3304
Vendor ID: 0x13d3 (AzureWave Technologies, Inc.)
Version: 0.01
Speed: Up to 12 Mb/sec
Location ID: 0x1a110000 / 3
Current Available (mA): 500
Current Required (mA): 100
hope there is a fix
Did you try using the DSDT edited by Maldon? It has patches in USB devices, it may help since your bluetooth has USB host controller.
can u give me the patch in usb devices to patch my dsdt . cause mald0n dsdt did no show my wifi
I read before that people are saying latest Chimera solved artefacting. But latest chimera (1.5.3) does not boot on my system, it says "Operating system not found".
If I then revert to older Chimera, it boots and even with the Intel HD 3000 injection (cause this injection is not included in the older Chimera).
OpenGL view ??
http://Olarila.com/Patches/Notebook%20Core%20i%20Sandy%20Bridge/EHCI.txt
and
http://Olarila.com/Patches/Notebook%20Core%20i%20Sandy%20Bridge/UHCI.txt
You can also apply this patch over Maldon DSDT
http://Olarila.com/forum/viewtopic.php?f=17&t=391&start=40#p3731
