Asus Z97-PRO (Wifi ac) - I7 4770 - HD4600
12 hours ago, MaLd0n said:
I never use it. need check opencore manual for that.
Ok, thanks
 have a problem: the computer shuts down but restarts with black screen can it be solved
post one video with this problem
link is dead
just test shutdown
4 hours ago, Fabio2203 said:
 XHCI-unsupported.kext
this hardware dont need it
idk what happens with shutdown
some usb hub?
some usb hub?
no
as pictured USB connected to motherboard cooling Corsair H80i
I have no idea what happens in this case
On 2/9/2023 at 3:46 PM, Fabio2203 said:
no
Hello Maldon
question: should i map it as internal
No
only Bluetooth, cams
question: when I have to map the usbs I have to use both kexts USBInjectAll.kext and XHCI-unsupported.kext, mapped the usbs I delete both kexts and use USBPorts.kext
ur hardware dont need XHCI-unsupported.kext
if u generated USBPorts.kext u can delete USBInjectAll.kext
