Trackpad does not work with Ventura
Hi,
I have an issue, i can not get the trackpad to be worked at all,
My Laptop:
Lenovo Legion Y540 (15) Laptop
CPU
Intel Core i7 9750H @ 2.60GHz
Coffee Lake 14nm Technology
RAM
32.0GB Dual-Channel DDR4 - 2666 MHZ
Storage
512 Seagate ST1000LM035-1RK172 (SATA (SSD))
931GB Samsung SSD 970 EVO Plus 1TB
Monitor
Generic PnP Monitor (1920x1080@144Hz)
Graphics
2047MB NVIDIA GeForce GTX 1660 Ti
Motherboard
LENOVO LNVNB161216 (U3E1)
Trackpad path
_SB.PCI0.I2C1.TPD0
Mac OS
Ventura 13.1
OpenCore
0.7.8
everything works very well, except the external gpu, and it will never work, because it is not supported
and the Trackpad
i also did all steps here
but GPI0 still does not have VoodooGPIO attached to it
This is my EFI, i removed Kexts files to reduce the size
Thank you.
Edited by Osama AlBanna
typo
u need use olarila efi folder for notebook coffeelake, if need use ur video patch, reboot and extract again
  • Thanks 1
