Hi ,
plesase someone help me to solve my problems ,
MB : Asus Z690-A Prime DDR5
CPU : Intel i5 13600K Raptor Lake
Ram : Dominator 32G ( 2X16G) DDR5 4800 ( 5600 )
SSD: 500G Nvme M2 XPG SPECTRIX S40G
SSD: 120G ADATA with SATA Cable
I downloaded ventura here
and then downloaded EFI for Raptor Lake CPU here :
and then bootable my USB and copy my EFI file ,
then i have this problems and my boot system going to stop  :
image.zip
now , haw can i fix this ??
and my EFI config file is this :
config.zip
my dGPU is :
ASUS RX 580 8G
