Hi!
I have an hp pavilion dv6 (3011el) with ml 10.8.5 and a ati 5650m.
Once installed I get battery, camera and all usb ports working, but I don't get QE/CI.
Forcing EDID, with GraphicsEnabler=yes and with Hoolock I get finally full hardware acceleration.
The problem is that once I force EDID I get the graphics card working, but I lost battery, camera and all the USB ports on the left side of the pc. If I put back the old EDID file nothing of these things back to work. Once I force EDID I lost them definitively. No kext works, nothing to do. I can't understand why.
Also HDMI and VGA port works in a bad way:
HDMI has no audio, a good resolution, but i completely lost the computer monitor that flashes a trembling copy of the external screen. In any way the OS recognizes that there is another screen.
If I link the VGA port I get on the second screen an incomplete copy with wrong and trembling colours of the internal screen and the OS doesn't recognize that I linked a second screen.
The OS recognizes the Ati 5650m and I have QE/CI.
Hi!
I tried to use Clover bootloader, but I can't get it to work. My motherboard has BIOS legacy (not UEFI) and nothing works after I have installed clover. All back to work reinstalling chameleon.
When I try to boot with clocer he says:
boot0
boot1h
and he stops
Hi!
After some attempts I confirm that Clover i s the solution.
I get full QE/CI without manually forcing EDID and all the problem that I had with Chameleon are solved.
Simply follow the guide linked by artur-pt.
Thanks!
