Need help to build full SSDT for i913900K and Tuf Gaming Z790-Plus WIFI D4
So, If I boot on this EFI (on a USB2 stick) I can launch on the Desktop and the system seems stable, but no Lan working and no inboard sound chip recognized. If I add the SSDT-UIAC.aml generated by the USB ports mapping with Hackintool, I can't boot up to the Ventura desktop... I also ran a cinebench benchmark (without the SSDT-UIAC.aml) and I lost a few hundred points in comparaison oh the EFI I gathered on various forums. I ran a geekbench but as I have no internet access without the lan working properly I didn't have the results.
common cinebench points is 34/36k on this hardware
save one ioreg
ioreg with this last EFI
EDIT : My mistake, this time the Hack with the SSDT-UIAC.aml added in the config.plist boot went through the end and display the Desktop. So I also did a ioreg output with the SSDT-UIAC.aml in addition to the ioreg without the SSDT-UIAC.aml. But still no lan working and no sound from the internal chip. Only sound via the HDMI of the RX6800XT.
iMac Pro.ioreg.zip
iMac Pro_with_SSDT-UIAC.ioreg.zip
Edited by JMB13
N o, still no lan ethernet working... Wifi is ON, onboard audio is on, but ethernet is not on. This ethernet is supoosed to work OOB using apple Ventura orginal configuration files. And it works that way on the EFI I gathered but that have so sleep/wake issues (kernel panic when the computer hibernates).
Capture d’écran 2023-01-30 à 14.37.32.png.zip
Edited by JMB13
thia lan card from ur mobo is a new generation. is not like previous mobos. new ids, new models.
I believe you. But on the EFI that works on this hardware I don't put any kext nor bootarg and it works perfectly.
By the way how did you manage to have a 25542 multicore score on geekbench on your setup ?
And do you know a tutorial explaininig how to patch a DSDT for a specific configuration ?
https://easyupload.io/rfersu
bios/uefi in full default and just set Vt-d and my xmp to 5600
u can check my files with full dsdt patched, native usb with oem ssdt and my ioreg
Archive.zip
