hideki2014 Posted January 30, 2014 Author Posted January 30, 2014 ok yes in hardware monitor i have CPU coefficient fixed at 16x for 1.5Ghz and when CPU need power coefficient grows up to 33x thats all. at the begining i don't use DSDT. where is DSSTgen.sh ? thx OS X Mountain Lion 10.8.5 Core i3 2120 3.30Ghz Asrock Z68 Pro 3M 12 Go DDR3 1333Mhz Geforce GT440 1Go 4x 2To HDD USB 2.0 2x 1To HDD USB 2.0 1x 1To HDD USB 3.0 1x 1To HDD Esata 1x 120Go HDD SATA 2.0 (OSX) 2x 40Go SSD Raid0 (Windows 7) 28" Screen
m.gbt Posted January 30, 2014 Posted January 30, 2014 Then just for testing, don't use the DSDT anymore and report what you see now in DPCIManager PStates. If you have all the states from 16 to 33, then you don't need to run ssdtPRGen.sh. - Now if without the DSDT you still don't have every levels from 16 to 33: In this world we need to search for information all the time, people never give you all the information pre-processed, you have to put some work and sweat too, otherwise even your dumb lazy neighbour will be able to have a fully perfectly running Hackintosh. Is that what you want? What will be the fun then? So, search in Google for ssdtPRGen.sh, exactly the name I told you. I allow you to copy-paste, don't be afraid. Then the very first link to appear in the Google results will be the script I'm talking about. Mavericks 10.9.2 Retail When you ask for support, remember to tell the bootloader you use
hideki2014 Posted January 30, 2014 Author Posted January 30, 2014 so i see that tomorrow i'm finishing to watch "game of thrones" anyway normally i disable the CpuState in the BIOS of my motherboard when i was on windows then if i don't have Cpu Stats i don't care just 1.5Ghz to 3.30Ghz when i need or always 3.30Ghz its good for me i will try without DSDT and with the script soon ^^ edit: Ok i have generated the SSDT table and now its working well with all state !! thx. OS X Mountain Lion 10.8.5 Core i3 2120 3.30Ghz Asrock Z68 Pro 3M 12 Go DDR3 1333Mhz Geforce GT440 1Go 4x 2To HDD USB 2.0 2x 1To HDD USB 2.0 1x 1To HDD USB 3.0 1x 1To HDD Esata 1x 120Go HDD SATA 2.0 (OSX) 2x 40Go SSD Raid0 (Windows 7) 28" Screen
m.gbt Posted January 30, 2014 Posted January 30, 2014 Great job, congratulations. That's hacking. You're taking the best out of your system. Keep it going Mavericks 10.9.2 Retail When you ask for support, remember to tell the bootloader you use
hideki2014 Posted January 30, 2014 Author Posted January 30, 2014 thx next i'll try to overclock a little i ve tryed ./ssdtPRGen.command 3500 but cpu max speed still at 3300 no a problem for now^^ OS X Mountain Lion 10.8.5 Core i3 2120 3.30Ghz Asrock Z68 Pro 3M 12 Go DDR3 1333Mhz Geforce GT440 1Go 4x 2To HDD USB 2.0 2x 1To HDD USB 2.0 1x 1To HDD USB 3.0 1x 1To HDD Esata 1x 120Go HDD SATA 2.0 (OSX) 2x 40Go SSD Raid0 (Windows 7) 28" Screen
