Hello guys, I have a problem with my bluetooth in Big Sur, the system detects it, but it is impossible to connect any accessory, I can't activate or deactivate it either, it always stays activated, I have tried several solutions that I saw on the internet but none have worked for me worked, I'll give you some screenshots so you can see what I have and see if you can give me a hand to make it work. Greetings and thank you!
Screenshot.zip
i think this bt lose support. check if have some project about that on github.
Hello Maldon, I finally found a used Intel wireless card that is compatible with all versions of mac by downloading the corresponding drivers in oc, it works perfect, but I still have a little problem with Bluetooth.  This works fine, it detects the devices and connects with them, but it doesn't give me the option to deactivate it and it always stays activated.  This happens in Big Sur, but not in Ventura, where you can turn it off and on correctly.  Do you know what could be due to?  I will be using some kext that interferes with it, I don't know what can happen.  Thanks.
Captura de pantalla 2023-01-19 a las 11.30.08.zip
