nwileck Posted January 23, 2014 Posted January 23, 2014 I installed mac os 10.9 (Mavericks) in my laptop but my monitor didn't show and i got raw data of my laptop lcd from windows then lcd work perfectly. But i have a problem. I want to show display dual monitor, when i connect external monitor with vga two displays show but system doesn't recognize dual monitor. System defines like one monitor. How can i adjust two monitor independently.
m.gbt Posted January 23, 2014 Posted January 23, 2014 There are some guides to activate VGA, HDMI and LCD but they are all video card-specific. So the first thing you should do is to discover what is your integrated GPU. You can see it in your laptop specifications page over the internet or if you know your exact processor model (Intel Core i7 doesn't say much) you can also search its specifications. Mavericks 10.9.2 Retail When you ask for support, remember to tell the bootloader you use
artur-pt Posted January 23, 2014 Posted January 23, 2014 hello how to .. sorry is in portuguese .. so use translator http://Olarila.com/forum/viewtopic.php?f=3&t=725 good hack PB Easy Note TM 86 - i5 430 M - H55M - Ram - 6 GB - Alc272 - Radeon HD 5470 512 QE/CI Lenovo G500 - i5 3230m - HM77 - Ram - 8 GB - Conexant audio - HD 4000 My OS X Files
nwileck Posted January 24, 2014 Author Posted January 24, 2014 My laptop specifications are: Intel Core I7 1.73 GHz 6GB DDR3 Ram AMD Radeon HD 6570M/5700 Series 1024MB this guide for intel hd 3000 can i do it for mine?
m.gbt Posted January 24, 2014 Posted January 24, 2014 I don't think so because if you don't have Intel HD 3000 then AppleIntelSNBGraphicsSB won't be loaded. You should discover what is your processor model and check if it has an integrated GPU. Intel Core i7 is not your processor model, it is just a very big family of processors. Check here on the left my processor model as an example. By the way I own an HD 3000 and it is not necessary to edit kexts to enable HDMI. In this case one most probably needs to edit the DSDT though but the advantage is that for future installations you can still use the edited DSDT whereas an edited kext can only be made in post-installation. Mavericks 10.9.2 Retail When you ask for support, remember to tell the bootloader you use
nwileck Posted January 24, 2014 Author Posted January 24, 2014 my processor model is intel core i7 740qm i got my laptop screen edid data on windows i think, can i get external lcd edid data on windows?
m.gbt Posted January 25, 2014 Posted January 25, 2014 Ok your processor doesn't have integrated GPU so you don't need to follow Intel HD Graphics guides. Your video output is certainly from your graphics card so you should search about it. Let's say you boot your PC without any external monitor connected. Then you connect it to VGA output. What happens? I didn't clearly understand. See if HDMI works, I found some reports about HDMI working fine on this board, so it should work for you too. I've never heard about using EDID for external monitors except for making some adjustments like frequency and colors, it should not be a solution if you have no image at all, I believe. Mavericks 10.9.2 Retail When you ask for support, remember to tell the bootloader you use
nwileck Posted January 28, 2014 Author Posted January 28, 2014 When i connected external monitor, shows same screen on two displays means mirroring but when i open display settings in system preferences doesn't show two display, just show one display and there is not button for unselected mirroring. For HDMI i haven't tried before.
m.gbt Posted January 28, 2014 Posted January 28, 2014 Are you using any patch to inject your display EDID? I've got the same behaviour once when I was injecting my display EDID on DSDT. The result was that it was forcing all the time the image to be shown on my laptop instead of an external device (but that happened to me on HDMI; haven't tested VGA). If you don't need EDID injection, don't do it - I mean, if you can reach the graphics without it. And if you do need, I recommend doing it by Clover instead of patching the DSDT. That's how it works here. http://clover-wiki.zetam.org/Configuration/Graphics#CustomEDID If you need help for that just ask. Mavericks 10.9.2 Retail When you ask for support, remember to tell the bootloader you use
