P8H67-M EVO - after shutdown system boots again
Hi,
I successfully patched DSDT from my Hackintos using DSDT patcher, 0 errors and 230 optimizations in the final dsdt.aml
System is snappy and all is good, except system won't shut down properly, it goes to shutdown but after 3-4 seconds it boots again. What is wrong?
I had to run Chimera 1.5.3 after injecting DSDT with multishit 'cause otherwise I lose good graphics with my builtin HD3000 graphics card. My cpu is 2600k.
send me kextstat
run on terminal
Here you go!
remove EvOreboot
shutdown in DSDT
remove EvOreboot
shutdown in DSDT
How do I do that? I removed EvOreboot from Extra-folder but that didn't work. I don't know how to remove that EvOreboot from DSDT, can you help with that? Or could you remove it and send the DSDT to me?
send me new kextstat
You have shutdown patch in DSDT
Method (_PTS, 1, NotSerialized)
[color=#FF0000]    If (LEqual (Arg0, 0x05)) {}
   Else
   {[/color]
       Store (Arg0, DBG8)
       If (LAnd (LEqual (Arg0, 0x04), LEqual (OSFL (), 0x02)))
           Sleep (0x0BB8)
       PTS (Arg0)
       Store (Zero, Index (WAKP, Zero))
       Store (Zero, Index (WAKP, One))
       Store (ASSB, WSSB)
       Store (AOTB, WOTB)
       Store (AAXB, WAXB)
       Store (Arg0, ASSB)
       Store (OSFL (), AOTB)
       Store (Zero, AAXB)
       Store (One, \_SB.SLPS)
[color=#FF0000]    }[/color]
Remove EvOreboot.
   Else
   {[/color]
       Store (Arg0, DBG8)
           Sleep (0x0BB8)
       PTS (Arg0)
       Store (ASSB, WSSB)
       Store (AOTB, WOTB)
       Store (AAXB, WAXB)
       Store (Arg0, ASSB)
       Store (Zero, AAXB)
Remove EvOreboot.
I've removed EvOreboot from Extra-folder but that didn't help, it still reboots after shutting down. Is it about removing something else also?
EvOreboot is in the kextstat you posted after saying that, are you sure you removed it?
You can try this patch in _PTS (like in Gigabyte mobos)
           Store (Zero, SLPE)
           Sleep(0x10)
       Else
           ... original code
and this in scope (/)
OperationRegion (PMRS, SystemIO, [color=#FF0000]PMBASE+30h[/color], One)
Field (PMRS, ByteAcc, NoLock, Preserve)
       ,   4,
   SLPE,   1
Check PMBASE in SSDT.
E.g.
Processor (P001, 0x01, [color=#FF0000]0x00000810[/color], 0x06) {}
PMBASE+10h=0x00000810
PMBASE=0x800
so you would use
OperationRegion (PMRS, SystemIO, [color=#FF0000]0x0830[/color], One)
http://osx86.co/f36/various-dsdt-mods-t1960/post41570.html
Hi and thanks for your input, but this goes a bit too far when it comes to my knowledge to hassle with the code...
           Store (Zero, SLPE)
           Sleep(0x10)
       Else
           ... original code
       ,   4,
   SLPE,   1
E.g.
PMBASE=0x800
so you would use
