apfs_module_start:1689 - Xeon E5-2620 - X79/C602 - HP z620 workstation
Hi, I am trying to install Catalina or any OS on HP z620 workstation, I used EFI x79 Desktop HEDT SandyBridge-E and IvyBridge-E and stuck at apfs_module_start: 1689, I searched for solution on internet and this forum but no luck, please help me!
Processor: Xeon E5-2620
24gb Ram
Video: Radeon RX560
Thanks on advance!
Edited by Alejo Boixados Caba
On 12/30/2022 at 8:26 PM, MaLd0n said:
Hi! thanks for ansewer! Look, I dont know if its ok but I add some SSDTs that I made with SSDTTime (see photo), with this SSDTs or only with the x79 got the same error.
In BIOS I dont find (have) CSM so I dont know if it is active or not, I only left active the UEFI mode.
I use USB 2.0, the pendrive and the port.
I reed something about the problem is related with the SSDT-EC wich is related to the USB ports, I maked my own whith SSDTTime but.... same error
I dont know what else to do....
Captura de Pantalla 2023-01-02 a la(s) 17.53.16.zip
I solved the issue, in a couple of days I going to upload the EFI folder, maybe it helps someone else.
