hard drive not detected while installing macos
I have a HP 250 G8 laptop
11th Gen intel Core i3-1115G4  TigerLake
While installing macos on stick with opencore, I get to disk utility ready to initialize internal hdd and then install ventura. Unfortunately ssd m2 is not shown (where windows11 is installed) and HDD is not shown (where I would like to install macos ventura). My bios doesn't show advanced options.
check if have some option about security on bios/uefi
If I put an m2 ssd with macos pre-installed in the laptop, opencore and macos installed normally appear when turned on! Perhaps the problem is the installation usb stick. I try to create a usb with macos installer, but with a usb 2.0 stick
I have Lenovo Yoga 7 15ITL5
I downloaded Hackintosh Mac os Ventura on my Laptop with OpenCore , the problem is that it does not show me Internal harad drives, i searched it so much and people said that i must change sata to ahci from bios , but i dont have any such option that can change my sata to ahci .
