Hi , I have successfully installed macOS Ventura on my laptop using your vanilla image with opencore and the EFI folders provided.
Issue: I'm facing an issue with touchpad not working. although that I have the kexts installed it still for some reason wont work. I have had this issue before too with MacOS Monterrey but i can't seem to remember how i fixed it. I can remember that it took me a while to do so. I appreciate all your support from now I'll be attaching the files that you may need. if anything is missing ill provide whatever is necessary for you.
Laptop Specs:
Model Name: Monster Tulpar T7 v20.3 ( it's a Turkish product )
Intel Core: Intel(R) Core(TM) i7-10750H CPU @ 2.60GHz   2.59 GHz
Intel: UHD Graphics Code name: CommetLake GT2 Revision 5
Core: 6 cores -- Thread: 12 Threads
RAM: 16,0 GB DDR4
Nvidia Graphic card: RTX 3060 Max-P
SSD: Dual Samsung 500gb 980
https://www.mediafire.com/file/3akop045t9w5qtu/EFI_COPY.zip/file
config.zip
